Old 01-05-2014, 03:35 PM   #1
New to all this
Hello everyone, I'm new to the rv world and will pester you all with questions about how to repair my junker
mcleland is offline   Reply With Quote
Old 01-05-2014, 03:38 PM   #2
crunchman12001's Avatar
mcleland,
Welcome to the forum.
What brand and make trailer do you call your junker? What year ect...
Any pictures would help us help you.
crunchman
2015 F-250 FX4
Old 01-05-2014, 03:54 PM   #3
I have a 92 allegro bay motor home and lost 12 volt power. I'm showing almost 14 volts but if I turn on lights or furnace power goes dead? I'm at a loss on what to do. I'm plugged into shore power and have a charger hooked to battery but same thing.
Old 01-05-2014, 04:09 PM   #4
ourflat's Avatar
Welcome! I believe most of us in the RV community have that special motorhome that got us started. Mine was a 2000 Fleetwood Tioga Arrow Class C. I started by searching the internet and manufacture websites for any thing I could to repair my MH. You'll be up and running in no time. Keep an eye on any water leaks on your coach since water damage is the hardest thing to repair. I had to rebuild the whole overhead cab because of a bad seal in the overhead cab window.
The other two items to keep a close watch on are relays and ground wires. Both can cause the problem you are experiencing.
Frank
ourflat is offline   Reply With Quote
Old 01-05-2014, 04:12 PM   #5
litgrep's Avatar
Are you on shore power, generator, running motor, or just on 12 volt? Sounds like bad ground or cables.
litgrep is offline   Reply With Quote
Old 01-05-2014, 04:25 PM   #6
I'm on shore power. I have a charger hooked to battery as a buffer but when I turn on furnace all power drops to 3 volts? Is there a way to bypass so I can run furnace since it's -5 up here rt now?
Old 01-05-2014, 04:40 PM   #7
bikendan's Avatar
welcome to FRF!
just so you know, Allegro Bay is not a Forest River brand.
so you should be able to get help with general RV things but not with things specific to your make/model of RV.
i would think that there's a Tiffin owner's website somewhere. they're pretty loyal owners of their Tiffin products.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-05-2014, 04:41 PM   #8
litgrep's Avatar
Sounds like a bad battery. Can you disconnect it an run on converter alone? Make sure terminals are clean. Also, verify your furnace blower moves freely. They're famous varmit homes and a stuck dc motor can do this too.
Old 01-05-2014, 04:44 PM   #9
Phat Phrog Stunt Crew
awwall's Avatar
Welcome to the Forum!! When you say "goes dead". what exactly are you saying? Goes to 0 volts? If not, what does the DC volts drop too? Knowing this would help in troubleshooting.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 01-05-2014, 05:46 PM   #10
rracer5's Avatar
Take the battery out and take it to an auto parts store like AutoZone. They will check its' condition for free. If it fails, they have RV/marine batteries in stock.
After that, if still nothing works, check all connections from the battery to the converter/charger. A loose connection will show 12v w/o load but if the connection isn't good enough under a load, the voltage will drop off cause "it can't flow thru a bad connection efficiently".
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
