Old 07-21-2011, 02:48 PM   #11
Wow, such great responses! Thanks. The skid wheels were what I was leaning towards but the point made about the weight on them and not on the wheels where it is supposed to be is making me rethink them. I also like the idea of dropping the WDH a notch. not sure I want to get into leaf springs etc... Thanks again for all the good advise. U guys rock!
rvannie is offline   Reply With Quote
Old 07-21-2011, 03:38 PM   #12
RubenZ's Avatar
Rvannie,
Can you post a pic of your setup? or a pic of a same model trailer. Maybe the trailer just sits too low. Thats how our old KZ was. Anything and I mean anything would make that sucker scrape the back.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 07-21-2011, 03:42 PM   #13
will do. will post it tomorrow.
Old 07-23-2011, 10:25 AM   #14
backin15's Avatar
If you have the torsion flex independent axels you may not want to drop the nose as you may overload the front axel and tires. If you have leaf spring suspension you would be ok because there is an equalizer so the load is shared between the axels if it is not level.
backin15 is offline   Reply With Quote
Old 07-23-2011, 02:30 PM   #15
Took it back to the dealer yesterday and they dropped the head 2 or 3 notches. Seems like that solved the problem for now. Thanks for all the help.
Old 07-24-2011, 11:42 AM   #16
Me and my husband just bought a wolfpack 27wp. Bought it online and didn't get to look at it until we drove 7 hours to pick it up. On the way home we found out the hard way that it is just way to low. We pulled into a gas station that had a small curb and funny pitch. The jack on the front drug bad no major damage though. Now that we got it home the spare tire drags at the bottom of our driveway and there is only about 3 inches of clearance under the tongue. It is a hill but not at all steep or difficult. This trailer is just way to low. The thing is in the shop right now getting the axles flipped. This should add about 4 to 6 inches, we hate to do this but it seems to be the only option. We go to Hatfield and McCoy trails and this is not interstate driving. We are afraid of tearing the thing up. I think this is just poor design, just like the lp tanks and generator rack on the tongue that won't let you make a tight turn. That problem has already been fixed. We will see if flipping the axles works or not. I like the trailer it just needs to be a little more practical and usable. We are hauling off road vehicles and don't need the low stance for loading street bikes. Maybe Forest river should offer an off road package for this use.
uglydog is offline   Reply With Quote
Old 07-24-2011, 01:31 PM   #17
Axle flipping?
Never heard of doing that. Too bad we can't jack up these trailers like so many of the trucks you see on the road and lift them that way. 5th wheels as a general rule don't have this problem either because they are higher off the ground. I think a pair of 8" lifts would work wonders except for catching the occasional wind gust!
Old 08-05-2011, 07:56 AM   #18
We just got back from Gilbert,WV. That was about 450 miles round trip. My husband likes the axle setup much better than factory. Instead of having about a inch of suspension travel it now has about 4. The suspension actually works like it should. The trailer pulls much better, it doesn't sway to much and doesn't seem top heavy or anything. All he did was take the axles out from under the trailer and put them under the springs instead of on top of them like it was originally. The axles are crowned (they are intentionally bent to handle weight) so you should make sure the crowns are up when you move the axles under the springs. This will require cutting the axle saddles off and welding them to the other side of axle. Saddles are just brackets for the springs to set on. My husband is a proffessional welder so it was no big deal. An rv dealer or local weld shop should be able to flip them for you if you don't want to tackle it yourself. The best part of this modification is that we can get up the driveway without dragging. I don't think we could have made it up the hill to campground either. I highly recomend flipping the axles.
Old 08-17-2011, 11:46 AM   #19
hoovercab's Avatar
We have a Flagstaff 829BHSS, we did not bottem out when we traveled, but we had problems with inclines. We are a low profile (and we do sit close to the ground compare to other styles). We had to get skid wheels to get up our small incline on our driveway. We would have taken off our waste lines () if we did not get skid wheels, but be careful get a good pair we got 5" and paid about 139.00 for them.My husband did not want to drill into the frame so this is the system he came up with, we have never had a problem with bottem out now that we have them installed. My neighbor bought a cheap pair and he took the off the first time he tried going down his driveway. We also had the RV dealer adjust the hitch system as ball part was sitting to high and forcing the rear of the camper down. We also have air suspension on our Navigator which is always adjusting to the load which sometimes works against us before the adjustments. Not sure if this helps, but you are not alone with low ground clearence.
Sheldon & Kathi Hartwell
Dexter and Ryley our beagles
2003 Forest River Flaggstaff 829 BHSS
2001 Lincoln Navigator All Wheel drive
hoovercab is offline   Reply With Quote
Old 08-17-2011, 12:54 PM   #20
TURBS's Avatar
so are the axles leaf or torsion now ?
