07-14-2018, 09:01 PM
new to rving
hello all, my wife and i are new to rving. We just purchased a 2019 Forest River Flagstaff Micro Mini. We are very excited for our first camping trip in a week. I have become somewhat familiar with out trailer.
My concern is i cannot find any kind of bypass valve for the hot water heater. How do i know if my hot water tank has water in it, All the plumbing is enclosed except for the freshwater fill hose in the one storage compartment bay, NO valves anywhere.
please help.
07-14-2018, 09:03 PM
Welcome to the world of RVing.
Open the hot water at either the kitchen or the bath sink or both. Keep them open until the sputtering stops and the flow is smooth. Then close them and turn on the water heater.
Mark Wilson
No trees were harmed while sending this message;
however, a rather large number of electrons were terribly inconvenienced.
TT: 2018 Surveyor 243RBS TV:2019 F-250 XLT 6.2L 4x4 Crew Cab
07-14-2018, 09:07 PM
reply
so there is no valve i need to turn, if i hook up to city water, the tank will fill up automatically, just need to clear the air out and then heat it up
07-14-2018, 09:25 PM
new to rving
My TT experience is that the HW bypass valves (if equipped) are near the tank. Can you find the tank on the outside and confirm you cannot access it from the inside? It would look something like this https://goo.gl/images/j34JjL
Another way to verify there is water in the HW tank is to open the safety valve to see if it is pressurized. of course make sure there is no possibility of hot water being in the tank. The valve is located behind the outside access panel and looks like this Camco 10423 1/2" Temperature and Pressure Relief Valve with 4" Epoxy-Coated Probe https://www.amazon.com/dp/B0006IX8AU..._J-QsBbA7SNCYH
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
07-14-2018, 09:29 PM
The freshwater nor hot water tank are visible. Everything is enclosed.
07-14-2018, 09:37 PM
i will check the relief valve in the morning. I just brought the trailer home on thursday, and guy that walked me around it did not mention how it gets filled or drained, just how to make sure the switch at the heater is in the on position and the one in the TT for electricity is on. That was the orientation for the hot water, he said he put about a 1/3 tank of water in the tank for demonstration purpose, ie, toilet flush and water in faucets.
07-15-2018, 01:31 AM
Your water heater tank IS visible, it's behind the outside hatch door.
That's also where you access the electric side switch, if it's a Suburban WH.
07-15-2018, 02:05 AM
please help.
I have No idea which Micro you have,there are Several Models,so here is my "WAG"! There will be a W/H access Door on the Entrance Door Side of unit! Now go inside and directly in front of that outside W/H Door will be your "Bypass Valves"! You may have to Remove Drawers/unscrew Panels/be a Contortionist/but the Valves are there! You will NEED to locate these NOW so when "Winter Comes" you can change them Back! Play House and Camp in your Driveway "Before you go Camping"! Youroo!!
07-15-2018, 08:44 AM
Your water heater will be behind an outside access door like the one in the picture below (colors will vary to match the RV paint scheme), but this will be the front of the water heater. Your bypass valves are most likely on the backside of the tank, and you may have to remove a drawer, fake panel, etc inside the trailer to be able to access it.
Locate the tank outside, then go inside and see if you can figure out how to get to the backside of the tank. You sometimes may even find access thru a storage compartment hatch near it.
2011 Flagstaff 831 RLBSS
07-15-2018, 08:48 AM
Also since this is your first RV, this thread may help in a lot of other things too.
http://www.forestriverforums.com/for...ts-157524.html
Good luck, and let us know if you get it figured out. You do need to find/access the water heater to make sure the valves (if equipped) are correct as many come shipped in the winterized position. If you do have a suburban water heater, it's also fully explained in the link above how to operate.
07-16-2018, 10:54 AM
Lol, I've had my Forester for 18 months. I live in south Georgia so don't winterize and everything is working properly so no hurry locating things. I took some time last weekend to remove some panels out of curiosity and found 3 valves behind the water heater, the furnace and ductwork, the Big Foot level sensor and the slide controller. I'd already located the Lippert modules when replacing the generator genie. Still looking for the router...I'll find it one day. Reminds me of an Easter egg hunt.
Kirk
2017 Forester 3051S
