Old 08-05-2013, 02:47 PM   #11
RasOne's Avatar
Greetings from Minnesota!
Welcome to the Forum!
Look for a couple small diameter (~1/2 inch) tubes below the area of your fresh water tank. One should have a valve or cap and the other should be open. The open one is a vent to prevent the tank from bursting if you leave the supply on too long. The one with the cap or valve is the drain to empty the tank and the one used to winterize your system. Good luck!
2014 Salem Hemisphere Lite 282RK
TV - 96 E150 Van 5.8L V8
Tekonsha P3 Brake Cont. w/EAZ-Lift WDH
RasOne is offline   Reply With Quote
