Old 08-01-2013, 05:53 PM   #1
New to the RVing world
Well we started with the Wildwood 29bhbs and now own a Sunseeker 3170DS. We love it. We recently picked it up from the dealer and they gave it to us with a full fresh water tank. Anyone know where I can drain the tank? I really don't need it full.
Iggy1021 is offline   Reply With Quote
Old 08-01-2013, 06:07 PM   #2
TURBS's Avatar
Welcome to the forum! congrats on the new sunseeker !
Look under the camper in the vicinity of where you fill the fw tank.
Hopefully someone with greater knowledge can help more !
Turbs
Old 08-01-2013, 06:30 PM   #3
Platokidd's Avatar
Welcome to the forum! congrats on the new unit!
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 08-01-2013, 07:36 PM   #4
wv campers's Avatar
Congratulations on the new camper.
wv campers is offline   Reply With Quote
Old 08-01-2013, 07:45 PM   #5
Thanks guys. Looking forward to gaining all the knowledge I can from this forum.
Old 08-01-2013, 07:49 PM   #6
dcheatwood's Avatar
Welcome. All 3 of my campers have had a screw-on cap on a drain under the fresh water tank. Look under the camper.
2018 Forester 3011 DS
Old 08-01-2013, 08:56 PM   #7
My first two rigs had a simple quarter turn valve on a small bracket near the frame to drain the fresh water tank. Sometimes they are on the side of a frame member and hard to see. Happy Camping!
2012 GMC 3500 Duramax Crew Cab, SuperGlide 20k
2014 Cedar Creek 36B4, LP Onan, Level-Up, Trail-Air pin, electric fridge
Campwell is offline   Reply With Quote
Old 08-02-2013, 07:47 AM   #8
dcheatwood's Avatar
Thanks campwell. My current RV has 1/4 turn valve. Other 2 had cap.
Old 08-04-2013, 09:37 AM   #9
2011 Forest River Stealth
rwtdct's Avatar
Welcome from the central coast of California
2011 Stealth CSFCK3214
2003 Ford F250 Crew Cab 4X4 7.3
2011 Polaris RZR 4
rwtdct is offline   Reply With Quote
Old 08-04-2013, 09:50 AM   #10
Camping Buddys's Avatar
Welcome to the forum, just open the shower, bathroom and kitchen faucets let them run and it will clean the gray tank and your driveway. (It's clean water) plus you'll try it all to see that it works.
John, Lilly & the kids.
2013 Surveyor Select SV 305
2011 Toyota Tundra crew max 5.7
https://campingbuddys.shutterfly.com/
Camping Buddys is offline   Reply With Quote
Old 08-05-2013, 02:47 PM   #11
RasOne's Avatar
Greetings from Minnesota!
Welcome to the Forum!
Look for a couple small diameter (~1/2 inch) tubes below the area of your fresh water tank. One should have a valve or cap and the other should be open. The open one is a vent to prevent the tank from bursting if you leave the supply on too long. The one with the cap or valve is the drain to empty the tank and the one used to winterize your system. Good luck!
2014 Salem Hemisphere Lite 282RK
TV - 96 E150 Van 5.8L V8
Tekonsha P3 Brake Cont. w/EAZ-Lift WDH
RasOne is offline   Reply With Quote
