Old 08-10-2016, 09:09 PM   #1
New to the site, thinking of buying ??
Howdy Yall I have a chance at what I think is a great deal.
A 2014 Rockwood Signature Ultra Lite Series , 3 slides. VERY good shape! ONLY $12,000 dollars!! One problem, Crashed in the back.
Been kind of soso repaired but needs a few cosmetic repairs inside AND I need to replace the big back window. Trying to find out where to get one right now.
Am I right, is this really a great deal for $12k or should I be worried about the repair on the back?
ID:	116876   Click image for larger version
ID:	116877   Click image for larger version
ID:	116878   Click image for larger version
ID:	116879   Click image for larger version
Name:	broken window.jpg
GDAWG1958 is offline   Reply With Quote
Old 08-10-2016, 09:36 PM   #2
asquared's Avatar
Hard to tell from the pictures exactly what the damage was. It looks like a crease on the side or is it decontamination from water damage? Seeing that window has me concerned about what kind of water damage that unit may have sustained from leaks at this point. Also was there any frame damage? I think you are looking at a lot of unknowns.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 08-10-2016, 09:51 PM   #3
Is the seller telling you how the damage occurred? If there's damage to the fiberglass or water inside any gains from the low cost will be lost on repairs.
todd172 is offline   Reply With Quote
Old 08-10-2016, 10:11 PM   #4
Someone ran into it. The bumper, tire carrier took the brunt of it. Had to replace the plate and studs under the window about 6 inches of subfloor across the opening where the chairs sit all with PT lumber. He also replaced the fiberglass sheathing , insulation on the back all the way across and half way up the window. sealed all with silicone, rubber mastic tape and that's white duct tape to cover the seams that you see. had to replace interior wall sheathing in same area with 3/8 smooth plywood.
No visible water damage, the underside, the covering on the bottom are all intact with no visible damage.
I know its not a best case situation. but again, from 3" past that back wall forward this unit is perfect.
Old 08-11-2016, 03:50 AM   #5
As I wrote "Duct Tape" I thought what am I thinking here? I was hoping myself or an RV service center could complete the repair properly for a minimal cost?
Old 08-11-2016, 07:16 AM   #6
Personally I don't know what a Rockwood Signature Ultra Lite 2 years old would cost however I know $12,000 is STILL a lot of $. My advice is offer
them ALOT less than the asking price. The trailer is damaged and from
experience I know almost no one will touch that trailer. You are buying
ASSUMING you will have no problems down the road. But if you do & have
to scrap it (worst case scenario) how much money are you willing to loose? Don't worry about insulting the owner. Remember he's not willing to use it.
Ian Walker is offline   Reply With Quote
Old 08-11-2016, 01:39 PM   #7
I saw a 16 used on RV trader for 19k. It's got few more upgrades but is essentially brand new. Personally I'd pass knowing it was rear ended. DW is an insurance claims manager, says you'd be hard pressed to get a company to help with any future issues. Good luck.
Old 08-13-2016, 05:36 PM   #8
Big1's Avatar
Hmmm, if it were me I would pass but that's me and then again it might work out find but you don't know good luck and let us know what you decided.
2017 Dodge Ram 2500 6.7L Diesel Cummins Turbo
2017 Denali Dutchmen 307RLS
Retired Army MSG.
Big1 is offline   Reply With Quote
