Old 08-17-2015, 03:58 PM   #11
With a little adjustment you should be good to go.
Papa GLS is offline   Reply With Quote
Old 08-17-2015, 04:04 PM   #12
Georgia Rally Coordinator
aceinspp's Avatar
Not all WDH are the same. Some work some are so so. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 30
Old 08-17-2015, 04:18 PM   #13
deartruc's Avatar
Sway that doesn't go away after a vehicle passes or you pass is where you want to be careful. You're dragging a box so wind approaching from the sides will pull and push you. If sway generates "on its own" is when you need to dial in your anti sway apparatus. You didn't say what type of wd and sway control you're using.
PS..I don't seem to have too much of a problem with semi's. I think those drivers tend to be aware of the affect they have on us. It's those tour buses that affect me. They fly on the highways.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 08-17-2015, 05:41 PM   #14
dcheatwood's Avatar
Some short sway when a large truck/bus passes is normal. Can be managed better with proper hitch setup.
And noise (popping, grinding etc) is not uncommon.
2018 Forester 3011 DS
dcheatwood is online now   Reply With Quote
Old 08-17-2015, 06:00 PM   #15
Bluepill's Avatar
Suggest that you experiment with tire pressures a bit. Sometimes a few PSI can make a difference.
Google "Trailer sway control" for some info.
Old 08-17-2015, 07:59 PM   #16
Stormrider151's Avatar
I don't know what tires you have but when I changed from the stock P metric tires and went with LT E tires it made a huge difference.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 08-18-2015, 10:57 AM   #17
All the above with the addition of keep your speed in control. My experience is the higher the speed the more sway I get. Remember the tires more than likely have a max speed range of 65 mph.
Be safe and
Bob & Jean
2009 Rockwood 8319SS - 2015 2500HD Silverado
Bandit & Tyler (long coat Chihuahuas)
"Having fun beyond our Dreams"
FourBits is offline   Reply With Quote
Old 08-18-2015, 05:36 PM   #18
PolarisGuy's Avatar
Oh and as far as noises... you should hear my Dad's Rage'n toy hauler. That thing sounds like the axles are breaking any time he goes over a speed bump. It's a well built toy hauler but man that thing is noisy!
RV: 2016 Stealth WA2916 Toy Hauler
TV: 2005 F250 PSD
2012 Polaris Sportsman 850XP
2014 Brute Force 300 (daughters)
2016 Days Camped: 22
Check Us Out On YOUTUBE!!
PolarisGuy is offline   Reply With Quote
towing
