08-17-2015, 03:05 PM
New to towing
Hello, this is our first truck and camper! Little nervous towing with noises and some swaying. Is it normal to have rpm between 2000-2500?
08-17-2015, 03:07 PM
Welcome. Lots of questions to ask...
Size and type of trailer?
What tow vehicle?
What kind of noises??
And no... swaying is not normal, however, we can probably get you settled in with a bit more info.
RV: 2016 Stealth WA2916 Toy Hauler
TV: 2005 F250 PSD
2012 Polaris Sportsman 850XP
2014 Brute Force 300 (daughters)
2016 Days Camped: 22
Check Us Out On YOUTUBE!!
08-17-2015, 03:09 PM
More info is needed. What tow vehicle,? what trailer? For some combinations that RPM is normal especially in Tow mode if used.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-17-2015, 03:24 PM
Georgia Rally Coordinator
Welcome to the forum. With a little more info as mentioned we can further assist you. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-17-2015, 03:38 PM
Sorry, thought my specs were there. We have 2015 Toyota Tundra double cab and 2012 Rockwood mini lite 2109s.
08-17-2015, 03:46 PM
You should b using some type of Weight distribution hitch(WDH) with your trailer. Also you did not mention gear ratio or engine size or speed you where driving, so I would say that the rpm may be right for about 60mph. Later RJD
Days camped 2019 62
08-17-2015, 03:47 PM
Do you have a WDH?
08-17-2015, 03:52 PM
Yes and sway bar. Still feel some swaying at times. Just want to know if that's normal.
2015 Toyota Tundra double cab V8 4.6
2012 Rockwood Mini 2109S
08-17-2015, 03:56 PM
Years ago, I pulled a similar sized trailer with a Nissan Titan. There should be no noticeable sway. Tighten the sway bar.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
08-17-2015, 03:58 PM
IMHO some swaying, especially when a long semi is passing you at a high rate of speed or in a strong cross wind is normal. However, although as you feel a slight sway, at no time should you feel "out of control" or be unable to keep the trailer from a dangerous sway pattern!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
With a little adjustment you should be good to go.
08-17-2015, 04:04 PM
Not all WDH are the same. Some work some are so so. Later RJD
Days camped 2019 62
08-17-2015, 04:18 PM
Sway that doesn't go away after a vehicle passes or you pass is where you want to be careful. You're dragging a box so wind approaching from the sides will pull and push you. If sway generates "on its own" is when you need to dial in your anti sway apparatus. You didn't say what type of wd and sway control you're using.
PS..I don't seem to have too much of a problem with semi's. I think those drivers tend to be aware of the affect they have on us. It's those tour buses that affect me. They fly on the highways.
2017 GMC Yukon
2018 Roo 23 ikss
08-17-2015, 05:41 PM
Some short sway when a large truck/bus passes is normal. Can be managed better with proper hitch setup.
And noise (popping, grinding etc) is not uncommon.
2018 Forester 3011 DS
08-17-2015, 06:00 PM
Suggest that you experiment with tire pressures a bit. Sometimes a few PSI can make a difference.
Google "Trailer sway control" for some info.
08-17-2015, 07:59 PM
I don't know what tires you have but when I changed from the stock P metric tires and went with LT E tires it made a huge difference.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
08-18-2015, 10:57 AM
All the above with the addition of keep your speed in control. My experience is the higher the speed the more sway I get. Remember the tires more than likely have a max speed range of 65 mph.
Be safe and
Bob & Jean
2009 Rockwood 8319SS - 2015 2500HD Silverado
Bandit & Tyler (long coat Chihuahuas)
"Having fun beyond our Dreams"
08-18-2015, 05:36 PM
Oh and as far as noises... you should hear my Dad's Rage'n toy hauler. That thing sounds like the axles are breaking any time he goes over a speed bump. It's a well built toy hauler but man that thing is noisy!
TV: 2005 F250 PSD
