Old 04-04-2012, 06:01 PM   #11
Turn on the gas purge the air and start the refer on gas. Should be an auto feature select that and go. Yes dump the black tank when at least 3/4 full. I usually leave the gray open closing it on the last evening. I then use gray water to flush the hose after emptying the black tank.
Old 04-04-2012, 06:07 PM   #12
GASPEDDLER's Avatar
Add some water to your black tank before using the throne. Helps keep things from drying out and sticking to your tank surfaces and sensors. When you get ready to head home and after dumping and rinsing your tank add some more water to allow some sloshing as you drive. This helps loosen anything you may have missed during the dumping/rinsing process. Do this last step only if you have somewhere to dump when you get home. I have pasture full of horse poop so I pull the valve as I drive through it. I too leave the gray open until the last evening. Two or three showers usually will fill my gray tank up the next morning.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 04-04-2012, 06:58 PM   #13
Herk7769's Avatar
Guess you head to the car wash after that...
HAM CALLSIGN - KC3FFW
Old 04-04-2012, 07:08 PM   #14
rracer5's Avatar
Some people are just lucky
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-04-2012, 07:11 PM   #15
Steve Jackson
sideout1961's Avatar
So there is no problem with the pilot blowing out on the fridge while driving down the road?
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 04-04-2012, 07:53 PM   #16
rracer5's Avatar
Not if your outside panel for the fridge is in place. And there is no "pilot" the flame is ignited by 12 volt electronic igniter. We've taken 4 8-10 hour trips with the fridge running on propane and arrived with my beer still cold while I set up.
2014 Sanibel 3250
Old 04-04-2012, 09:00 PM   #17
GASPEDDLER's Avatar
lol, I'm careful what I step in!
Equalizer E2 Hitch
Old 04-04-2012, 09:06 PM   #18
Current River Rat
Traveling with fridge on gas
Just be cautious when pulling in to gas stations and fueling the TV. It's advised you shut the fridge down before you pull to the pumps unless your fridge is way back on the trailer and it is well away from the pump islands.
Bruce & Sarah Tanner
Bttravel is offline   Reply With Quote
Old 04-04-2012, 09:13 PM   #19
Steve Jackson
Bttravel great advice, never would have thought about that.
Old 04-04-2012, 09:20 PM   #20
JoeR's Avatar
Yeah, if you leave the black tank valve open all weekend, you figure out what the term "poop pyramid" means....
2008 Toy Tundra DC 5.7L Bagged w/LTs
Hensley Arrow
2012 Windjammer 3001W, Atriumed
JoeR is offline   Reply With Quote
