Old 04-05-2012, 06:54 AM   #21
jamar's Avatar
Originally Posted by f1100turbo View Post
select auto on your fridge then it will be gas when there is no shore power and when you hook up to shore power then it will switch to electric.
no WE use our fridge going down the hiway but thats a big topic around here weather to do it or not . IVE NEVER had a problem.
dump at the end of your weekend camping trip black first then gray second.
X2
We always run our fridge while traveling. We've never had an issue.
jamar is offline   Reply With Quote
Old 04-05-2012, 06:56 AM   #22
jamar's Avatar
Always fill those those tanks up before dumping. Sometimes we even ride home with them full, to help break everything up and then dump when we get home.
Old 04-05-2012, 07:05 AM   #23
Triguy's Avatar
Another good way to break it up once you are ready to head for home is, after dumping the full black tank, fill it up with 5 gls of water and add all of your ice cubes into the toilet. Then drive home. The ice cubes help to knock crud off the sides and the monitor. I've got a 30gl BW tank so you might need more than 5gls.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-05-2012, 07:16 AM   #24
jamar's Avatar
[QUOTE=Triguy;177861]add all of your ice cubes into the toilet. Then drive home. The ice cubes help to knock crud off the sides and the monitor. [QUOTE]
I've heard of this as well. Good idea too.
Old 04-06-2012, 09:38 AM   #25
rracer5's Avatar
Originally Posted by Bttravel View Post
Just be cautious when pulling in to gas stations and fueling the TV. It's advised you shut the fridge down before you pull to the pumps unless your fridge is way back on the trailer and it is well away from the pump islands.
I've mentioned this in previous posts. Also, a lot of tunnels and bridges require you to turn off all propane before going over or through them (ie;Chesapeke Bay Bridge and Tunnel syatem).
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
