Old 07-26-2015, 08:41 PM   #11
Ok, just went and looked at mine. On the skirt just aft of the slide out it has a label that says wastewater holding tank. This is the galley tank. Way back in under you will see a pull handle. You will have to get down on your knee probably to see it, but it is there. The piping does go into the main drain just before the dump hookup. There is not a separate hookup for the galley tank. Hope this helps some more, if not we will try again. Good luck.
dmac1951 is offline   Reply With Quote
Old 07-27-2015, 08:07 AM   #12
Thanks. I found it yesterday after I saw that there was a cable to the T handle. Now I can do the dishes again.
chateaunu is offline   Reply With Quote
Old 07-27-2015, 08:12 AM   #13
Great. that think is way up in under the skirt. I had to get down on the ground to find mine the first time.
Old 07-27-2015, 01:46 PM   #14
"Just living the dream"
Welcome from Ontario, Canada....
Chunkem is offline   Reply With Quote
upgrade
