Old 04-22-2015, 11:52 PM   #1
New Used Rockwood XL 1270SS
Hello,
I am a new member
I was given a USED Rockaway 1270SS
I am trying to find whatever I can about it, floor plans, as built, reasonable options I can add....
I know as currently configured, single axle, new tire, correct air pressure, empty Propane tanks, it whips excessively behind my Ford 1997 F150 XLT. I tow a single axle, tri hull boat and that tracks beautifully behind the rig.
I just bought a sway control bar to attach to the trailer because the rigs whips violently....
Any help on the above is appreciated..
rjaggi123 is offline   Reply With Quote
Old 04-23-2015, 12:51 AM   #2
bikendan's Avatar
Do you mean a Rockwood, not Rockaway
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-23-2015, 09:06 AM   #3
Yes, Rockwood XL, Any Help ?
Old 04-23-2015, 09:22 AM   #4
Mowgli64's Avatar
Welcome to the forums.
I would check/replace wheel bearings. The sway control should help but a pop up should not sway that bad. If you still have troubles may need to check alignment of axle?
2015 Wildwood X-Lite 271RBXL
2013 Ford F150 Crewcab Ecoboost
Mowgli64 is offline   Reply With Quote
Old 04-23-2015, 09:51 AM   #5
Is the trailer level when you are towing . popups don't like to be towed nose up, this can cause sway. What is your tongue weight need, light tongue weight can also lead to sway. I towed a 12 ft palomino behind a Volvo V70 and a Kia sedona without sway control and never had any issue with sway.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 04-24-2015, 09:14 AM   #6
Thanks How do I get something like a owners manual ??
I will make sure it is Level , it may be Nose up now, it will not be soon
