Old 12-26-2013, 07:54 AM   #1
Newbie
My husband and I are expecting to pick up our new Sunseeker 2300 next month. We've been camping in a tent for years and once had an old motorhome in the 90's but we are new to Forest River. We are so anxious to get started again in the new unit. Any words of advice to some newbies? We'll have an arctic package. How well does this work in cold weather? How cold?
Wray Sunseeker 2300 is offline   Reply With Quote
Old 12-26-2013, 07:56 AM   #2
MtnGuy's Avatar
to the forum !!
Old 12-26-2013, 09:30 AM   #3
Welcome form Wisconsin and congrats on your new Sunseeker 2300.
Old 12-26-2013, 09:36 AM   #4
Ford Idaho's Avatar
Welcome to the forums.
Old 12-27-2013, 12:20 PM   #5
Anacortesians
Read the literature on the "Arctic Pack" carefully. It seems to have changed a lot over the years and between different manufacturers and models. The stupid system we have just heats the waste tanks. The thermostats are not adjustable and switch ON when the tank temps drop to 40F and stay on until 64F. The heaters (2 on each tank) each draw 7 amps from the house batteries. I'm not interested in heating the sewage to 64 degrees while pulling 28 amps out of the batteries! They also don't sense whether the tanks are empty and I was concerned about them getting hot enough to soften the tank bases.
It's disconnected now.
Frank and Eileen
No longer RVers or FR owners
Old 12-27-2013, 07:38 PM   #6
We have a 2011 Sunseeker 3100 with the arctic pac and have never used it. The LP furnace heats the tanks, water filter and pump, and the dump station compartment. We've been in the coach overnight in 19 degrees F with a 20 mph wind and had no problem. I checked the compartments the next morning and they were over 50 degrees.
For your information, if you are camping in cold weather and don't have an electrical hookup, the furnace will use about half the power of two batteries overnight. You'll need to run the generator several hours to fully recharge the batteries. Having the batteries run down during a cold night when you aren't allowed to run the generator is not fun! You can get by just fine with a 20 amp hookup for the furnace if the refrigerator is running on LP (it uses a little 12 volt power even when on LP), you don't use an electric heater, and you don't use too many lights at once. However, if you have LED lights, you shouldn't have to worry about using lights.
Also, for information, the coach's 12 volt system normally starts the generator. If they batteries are run down and you don't have electrical hookup, you can start the chassis engine which will give enough 12 volt power to the coach's system to enable you to start the generator, then shut down the chassis engine.
Look through this forum. There's lots of information on the Sunseeker/Forester lines, their appliances and system.
By the way, if you have internet access during your campouts and run into a problem, you can often get help from forum members fairly quickly. Just post your problem with something like: Need Help about XXXX - On The Road.
PS If the furnace hasn't been run much, run it for at least 15 minutes with the door and some windows open before you leave home. New furnaces burn off some residue and can set off your smoke alarm.
RamblerGuy is online now   Reply With Quote
newbie
