Originally Posted by Neil Sims
I am a total novice when it comes to RV'ing but I learn quickly and fortunately have some capabilities to fix things. Limited as it may be!! LOL!!
Congratz on the new RV and welcome aboard Neil.
The below is a copy and paste of useful information, and I usually recommend it to those just starting out. Some of it, you may already know, or may not be applicable to your particular RV. You will be able to filter out what pertains to your situation or not. I would suggest you read the electric threads and energy management first, and then the converter thread. This will help explain your different electrical systems of your RV, and how they operate...as well as what the converter does. The very first link will explain what operates off what system.
You can just peruse at your leisure as you get to know your RV:
Basic electric:
Basic RV Electricity - RV Information (RV Maintenance)
RV Electric
Your very important converter:
RV Converters and Amp Draw - RV Information (RV Maintenance)
Installing a dedicated 30 amp RV outlet at home (Make sure you understand it's 120 volts ONLY):
How to wire a RV 30 amp outlet
12 volt DC:
12 Volt DC Circuit Breaker with Manual Reset
The 12volt Side of Life (Part 1)
Suburban water heater (if applicable to your RV):
Suburban's electric switch and much more
Suburban Water Heater Video Guides
Water Heater bypass/crossover valves:
NO (OR LUKEWARM) HOT WATER -Please read first
And the newest additions to help understand what constitutes a true full cylinder in refilling vs exchanging propane cylinders... as well as how the automatic propane changeover regulator works:
Propane Cylinders (Refilling vs Exchanging)
Propane automatic changeover regulator
Inverters and residential refrigerators in RV's:
http://rveducation101.com/articles/rvinverters.pdf
Bobby
