The fan is in the converter that changes 120 VAC to 12 VDC to charge the battery and operate the 12VDC equipment (fridge & furnace "brains," hot water heater, 12 VDC lights and vent fans, AC & furnace thermostat, electric jack if you have one, slide out if you have one, etc.) Usually the fan runs when you put more than a minimal load on the system. It will also run if the battery is low on charge and the converter is recharging it.
Assuming you're not running a bunch of lights, I'd guess the dealer recently installed your battery and it is not fully charged. Once it's charged, the converter fan will probably shut off.
2011 Traverse LT, 3.6L, FWD
