05-23-2018, 01:45 PM
Newbie with a GT5 36B
Hello All,
I am new to RVing and just purchased a GT5 36B. Trying to learn about everything in the RV as the manuals aren't that helpful. Any suggestions are welcomed. I know I will ask questions, like this one:
I cannot find the fresh water tank drain and I have 80 gallons of water in the tank. Any suggestions on where to find the drain valve?
Rick
05-23-2018, 04:09 PM
Welcome from SW Ohio .
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
05-23-2018, 07:31 PM
Thanks, geman53. Looking forward to being out there with my grandkids, daughter, and her husband
05-23-2018, 07:43 PM
Does your rig look like this?
Around 4 minutes in they show where the fresh water drain is...
If it doesn't look like this.... nevermind.
2015 Dynamax REV 24TB class C
05-23-2018, 07:46 PM
It does thank you so much
05-23-2018, 08:00 PM
Sounds like you had the usual crappy PDI. I'm guessing you'll be back with more questions. We'll be here to help.
2011 Traverse LT, 3.6L, FWD
05-24-2018, 08:14 AM
PDI? Thank you very much!
05-24-2018, 09:34 AM
Welcome.
05-24-2018, 09:47 AM
Your drain will be underneath next to your fresh water tank vent. Blue pex with a cap on it. You most likely will have 4 drains underneath. 3 blue and 1 red. 1 of the Blue lines will be your tank drain.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
05-24-2018, 11:21 AM
I did locate them. Do you happen to know what the other tubes drain?
05-24-2018, 12:07 PM
They are the low point drains for winterization.
05-24-2018, 12:12 PM
Thank you, being new at this is frustrating at time because of the learning curve.
05-24-2018, 12:24 PM
Feel free to ask me anything. I have the '16 model (364TS) of the 36B and have a fairly good knowledge of all systems.
05-24-2018, 02:12 PM
PDI - Pre Delivery Inspection
Here's the link to the PDI checklist, which one should use when purchasing a rig:
http://www.forestriverforums.com/for...do=file&id=112
