Old 04-11-2012, 08:04 AM   #1
Karrie74's Avatar
Newbies
Good morning. We just purchased our first RV from RV Nation in Hamilton, Ohio. We bought a Cedar Creek 36B4. We are excited, anxious, overwhelmed, and nervous! We have 3 kids - 15, 12, and 8 and wanted to find a way to spend some time together without the hassles and stresses of everyday living.
We stayed at Kentucky Horse Park on our way home and was very pleased with the cleanliness of park. we would go back again.
One quick question, my husband wants to screw some diamond plate onto the underneath of the front to keep it from put damaged. Does anyone know if there is a solid piece of plywood across there or just 2x4's?
Thanks, Karrie
Karrie74 is offline   Reply With Quote
Old 04-11-2012, 09:06 AM   #2
A little better explanation would help, do you mean on the front surface below the front storage door or under the front where the landing jacks come out of the bottom?
Old 04-11-2012, 09:17 AM   #3
There is no such a thing as a 2X4 in trailers except maybe Teton.
Your fiver is aluminum frame construction. There will be aluminum studs all over the place. Generally 16 inches OC, but in that area all bets are off. Just wax the heck out of the area and you will be good to go. Mine has been like that since 2005 and still looks good. Yea, there is some dirt and tar on it that i should scrub off, but under there is extremely hard to get at and work on for an old man, so I wash it and leave it alone.
I sure hope you have a dually, because that is one heavy mother. And once you get it loaded up with "stuff" and drive across the scales you will probably find that you are very close to the trailers GVWR.
Old 04-11-2012, 09:37 AM   #4
Karrie74's Avatar
Sorry, this is not my area of expertise. The area around the hitch that hangs over the bed of the truck. Its the "bottom" of the closet for the upfront bedroom. when we brought it home there was a small hill and coming in from an angle the front of the trailer dipped down and scrapped along the bed of the truck. He wants to cover that up after he caulks it, so that it doesn't happen again. He needs to know if there's anything to screw into.
We have a 2008 Dodge 3500 Diesel Dually. thank Goodness my husband has pulled equipment trailers in the past because this camper this rather long!
Old 04-11-2012, 11:21 AM   #5
As was said before, there are no 2 x 4's in the unit. He should be able to find some supports either steel or alum to attach it.
Old 04-11-2012, 12:30 PM   #6
TURBS's Avatar
look where the cover there now is attached . the screws there already show you where supports are .
Old 04-11-2012, 12:51 PM   #7
OK, now that makes far more sense. First things first. When hitched up and ready to travel you need to measure between the bottom of the trailer and the top of the bed rails. You need to have about 6 inches. Any less and you will hit. Adding sheet aluminum will only make it worse. He needs to crawl under the trailer and see if there are different holes in the spring hangers. If so then you need to move the springs down to the bottom set of holes. This will raise the trailer a couple of inches. While he is at it you need to install a wet bolt kit. Do a search on that subject for more information. Then as a final step you need to readjust the hitch to get your trailer back towing level. Any questions so far?
Old 04-11-2012, 12:51 PM   #8
Karrie74's Avatar
Thank you all for your advice, I will relay this to my husband.
Old 04-11-2012, 01:17 PM   #9
He may want to raise the fifth wheel in the truck or lower the hitchpin on the trailer to increase distance between bed sides and the trailer. Wouldn't mess with the springs on the trailer other than the "wet" bolts.
Old 04-11-2012, 01:26 PM   #10
That makes absolutely no sense? Moving one up and one down will in effect leave the bottom of the trailer overhead in exactly the same place. The OP is hitting the bottom of his fiver with the bed rails and the only solution is 1) get the truck lower or 2) get the trailer higher. Which option is easiest and most cost effective? Getting the trailer another two inches up in the air, unless there are no other adjustment holes.
