If you have a connection coming from the RV body that looks like the below connection, it's most likely a low pressure hose. With a low pressure feed, you cannot use a grill that has it's own pressure regulator (you can only have a single regulator in use). There are portable RV grills out there that are made for this type of connection. In my case, I wanted a grill with legs so I removed the pressure regulator from my grill and added a quick connect connection. If I need to use bottled gas, I can easily replace the hose with the pressure regulator. Hope this helps. Larry G.
2021 Silverado RST Z71 4x4 6.2L
2021 Flagstaff Micro Lite 25FKS
USMC (Retired) '70-91
