Old 02-21-2014, 12:00 PM   #1
senior country vet
highcountryCo's Avatar
Thumbs up old rver new to forum
Hi I am new here. bought 2014 316 vengeance TH in AUG have some issues but like the rig. tow with 2012 f350 6.2 auto. changed 3.73 to 4.30 gears unloaded mpg dropped to 17.5 from 19.5 , with FW it went up from 7 mpg to 9.5 to10.5 mpg and pulls much better. still cold here in NW colo. with snow on the ground. TH in for warr. will head out when its done. Used it about 60 days last fall(retired). Well that's Me. Have fun!!
highcountryCo is offline   Reply With Quote
Old 02-21-2014, 12:33 PM   #2
jevanb's Avatar
congrats, when we were looking at TH trailers we really liked the vengeance line, getting 10.5 towing a 13-14k 5er with a gas motor is impressive in the Colorado hills, our work truck f250 regcab, 4x, 8ft box, 2013 sees that empty with nothing buy 2 people in the cab and bed empty.. ??? what else was done to the TV
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 02-21-2014, 12:44 PM   #3
MtnGuy's Avatar
to the forum !!!
Old 02-21-2014, 03:04 PM   #4
senior country vet
vengence 316
in the mts of colo the mpg stays closer to 8.5-9 ,on the flats & mts of northern nev. it avgs 9.5-10 this is holding the speed to 60-63 mph at 65 to 70 mph & up it drops to 7.5 to8 75 &up it drops to 6.5 or lower depending on how hard you push it. the lower gears is the only mod but if you use tow haul mode mpg is worse I get this mpg only when using the manual mode on my 6 speed because I can select the gear & speed I want to use and its locked there instead of shifting all the time and turning very high rpm to hold a given speed. You may have guessed I am retired so I don't have a set time to be anywhere, its a nice way to travel. Hope this helps you. be aware many mods on the new ford trucks the computer will track even if mods are disconnected and will void your warranty. good luck Ron
Old 02-21-2014, 05:50 PM   #5
Welcome from Wisconsin!
