Old 08-04-2014, 08:49 PM   #1
oven range vent
just bought a flagstaff 8528rsws (5w) and i can't figure out how to open the outside vent. i was told to just push up on the tabs. i tried that with no success. i am afraid to push any harder than i did because they will break. any help would be appreciated. also a photo of the vent open would help.
thanks in advance,
russ
RMFrawley is offline   Reply With Quote
Old 08-04-2014, 08:56 PM   #2
I am going to assume that its the same as mine........
It will open it took me a couple of tries, I had to push up on the two tabs and pull out at the same time. I also thought it was going to break but it didn't
2014 Rockwood 2604 WS
Chev 4x4 2500 HD v8
tugger is offline   Reply With Quote
Old 08-04-2014, 08:58 PM   #3
They can be a pain but will operate easier over time.
Old 08-04-2014, 09:00 PM   #4
jtstromsburg's Avatar
If I recall, I think I gently pried ours open the first time. There has never been a second as I left it lose and it's never been a problem
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 08-04-2014, 09:35 PM   #5
asquared's Avatar
Ours was caulked over a bit. Peeled back some caulk and it worked well. You have to push up and out to get it to open.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 08-05-2014, 08:05 AM   #6
hi,
does the tab swing the flap in or out. it looks like the tab pivots on a center pin causing the plate to swing in. but in was mentioned about prying it open. can someone attach a picture of it open.
thanks again,
russ
Old 08-05-2014, 09:06 AM   #7
Mr. Dan's Avatar
Same here. Tech cut the caulk on the trailer's 2nd trip to the dealership for warranty work.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 08-05-2014, 09:22 AM   #8
mjones12's Avatar
I've had most of the same experiences described here. It DOES get easier with time. I've also found that it's easier for me to get one side loose before working on the other side.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 08-05-2014, 09:50 AM   #9
Does anyone know where, or even better yet a DIY way to fix the flap on these? I have 2 tabs that rotate as well as two tabs that stick out near the top of the flap so that the flap can "hinge" and swing open. One of the 2 ears or tabs at the top of the flap have broken causing the entire flap to fall out if I open the vent. Pain in the butt....Gotta come up with a way to make new "ears" at the top and some way to make a new rotating tab at the bottom.
DHAJMoore
TT 2007 Forest River Shamrock 21RS
TV 2013 Ram 2500 5.7 Hemi Gas
davemoore99 is offline   Reply With Quote
vent
