Old 07-24-2012, 06:27 PM   #1
Retired HVAC Tech
I am a retired commercial Mechanical Contractor; I spend over 35 years involved in the Commercial Heating and Air Conditioning industry. Now my wife are full timers traveling while we can still sit or stand and take nourishment with out help.
See ya on the road
HVACretired is offline   Reply With Quote
Old 07-24-2012, 06:34 PM   #2
troyt's Avatar
Welcome and Congrats on the retirement! Your HVAC experience will be handy to the forum so don't stray away to often.
2006 Dodge 2500 Crew Cab 5.9L Cummins 4X4 200k mls
2010 Forest River Flagstaff 831QBSS - Equal-i-zer Hitch
2011 HD FatboyLo & 2000 Honda Shadow 1100
Nights Camped 2010 (7), 2011 (15), 2012 (35) 2013 (40) 2014 (22) 2015 (12) 2016 (10) 2017 (?)
troyt is offline   Reply With Quote
Old 07-24-2012, 06:44 PM   #3
Herk7769's Avatar
I have many Air Conditioning questions so read up on RV air conditioners and low voltage "work around"s.
I will be needing a fix before we go back to Gettysburg next year.
PS - Welcome to the board!
HAM CALLSIGN - KC3FFW
Old 07-24-2012, 07:12 PM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
to the Forums. I'm still in the HVAC field but in the Residential Side since I got out of High School in 1976. Enjoy your retirement and your travels. Unfortunately I still have too many years to go until I retire but it's getting closer each day.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 07-24-2012, 08:35 PM   #5
work around
Do my best to help out anyone I can
Old 07-25-2012, 07:32 AM   #6
Herk7769's Avatar
This thread is awesome and answered my questions.
Lou
Old 07-25-2012, 09:22 AM   #7
Rockdad's Avatar
Im an Hvac tech ~not retired~ contractor. Sad isnt it? Resi and Lt Commercial. My back and knees hurt. We just started getting out with the camper on weekends this year now that the kids are motoring on their own. Congrats on your traveling retirement!
My Love , My Life ~ My Wife
Rockdad is offline   Reply With Quote
Old 07-25-2012, 10:30 AM   #8
Wanna Be Camper
SaskCampers's Avatar
Welcome to FRF and safe travels.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 07-25-2012, 06:51 PM   #9
Well done. Enjoy your retirement and you will enjoy surfing the FR forums. I have 36 years as a service tech for a pretty big outfit and hope to retire in 4 years. Happy trails.
Jim & Kathy
Bailey, waiting at the Rainbow Bridge
Gracie, a rescued Beagle
2007 Chevy Tahoe
2008 FR Surveyor 233T
JimChow is offline   Reply With Quote
Old 07-25-2012, 07:38 PM   #10
I am getting a lot of questions about AC because of that I am going to post some comments I sent out recently that may help some others. If you fell like I am rambling just delete it and sorry for talking your time. That being said I am always available to answer questions whenever I can help.
You said that you turned the thermostat up to turn it off and back down within a minute. That in its self can create a problem because that short period of time does not allow the compressor to equalize. When the AC is running you have a 250 lbs. to 300 lbs. of pressure on the discharge side of the compressor and around 60 lbs. on the inlet side. As you can imagine the motor doesn’t like to start against a 5 or 6 to 1 ratio (it’s like trying to start a car in gear). That’s why the newer systems have a 5-minute time delay built into the system.
That being said if the pressures are equal and the voltage is correct you should not need a Hard Start Cap. I would check to make sure that the voltage is over 110 VAC when the AC is running (Check this at the AC unit in the ceiling). A hard start kit is a bandage for something that not correct with the compressor or the power supply feeding the compressor.
Along those lines a 2000-Watt compressor is probably NOT enough to run a 12,000 or 15,000 btu AC. There are a couple of reasons, 1- most 2000 watt Gens are only rated at 1800-Watt continuous duty (15 Amps 120 VAC). A 12,000 btu. Two, the AC that runs at 12 to 13 amps @ 120 VAC has a momentary start up current of 25 to 30 amps @ 120 VAC or 3000 t0 3600 Watts. Starting a motor is like pushing a car the first 10 feet is really hard but after you get it moving it’s not so bad. An electric motor is the same because the first few revolutions the motor will draw 2 to 2 times the run load amps. That’s why I say the 2000-Watt Gen is really not adequate for a 12 mbtu. or 15 mbtu. AC even though the run load amps are less than what the max amps are on the Gen.
Now as for low voltage as the voltage goes down the amps go up. Work is a combination of volts and amps which = watts or work. Any motor or inductive component will suffer from this; a 10% decrease in voltage creates a 10% increase in amps. That’s what burns stuff up NOT the low voltage but the by-product of low voltage, which is high current (amps). Resistive components do not suffer for this problem only happens with inductive parts like motors & relay coils. But that’s not the end of the problem as the voltage goes down and current goes up the wire it's self heats up because of the high current and when that happens the resistance increase and the voltage drops even more.
So as you can see any voltage under 110 VAC will create problems serious problems, in most case low voltages cause more problems that high voltage because of the high current by-product.
Next NO Cooling after long run time, IF (key word IF) the compressor is still running you probably have a freeze up problem. Indoor coil freeze up, this is only caused by one thing LACK OF AIR FLOW ACROSS THE COIL when its over 75 degrees outside. This can manifest its self in several ways:
*Fan failure
*Dirty air filter
*Impacted Evap coil (indoor coil). This is dirt in between the fins
*Dirty Evap coil surface (indoor coil).
*Inadequate ductwork (Not uncommon in an RV). Duct work to small.
Low Freon will not freeze up an Evap coil at normal operating temperatures. That being said if you are low on Freon your compressor will overheat and shut down after 5 to 30 minutes of run time depending on how low it is. THIS IS NOT COMMON and usually results in a burned out compressor in short order.
Now after all of that remember that on a hot day with sun shining in all of your big windows your AC probably will not be able to keep up. If it’s a scorcher keep the shaded drawn on the South side along with the East in the morning West in the afternoon.
