Looking at pics of your model, I'm betting the WH is located behind the black panel that is located outside between the furnace vent and your front storage hatch. From the inside, that would be under/near your kitchen sink. Should have 2 snap/twist latches to keep the cover in place. If yours is like mine, there is a second hard to see electric switch on the WH itself that is accessible from outside the trailer. Probably a black rocker switch.
Also check that the bypass valves are in the right setting.
Good luck.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
