Old 07-28-2016, 09:29 AM   #1
roof cleaner damage to sides
I have cleaned a rubber roof and did not rinse sides of trailer quick enough. Cleaner left white streak marks on all sides. also cleaned the roof in hot weather. I have used Awesome, Simply Green, , Mr Clean scrubber, WD40, rubbing compound, black streak remover, lots of Elbow Grease, RV wash and Wax all to no avail. Streaks appear to be removed when first washed/dried but appear to come back. Less noticeable but still there. Manufacturer has wrong contact number on product and web site difficult to negotiate. Any help would be greatly appreciated.
Happyherz is offline   Reply With Quote
Old 07-28-2016, 10:26 AM   #2
NMWildcat's Avatar
Ouch! Sorry to hear about the streaks. That happened to us on one of our first RVs when we used what we thought was a good product for cleaning our rubber roof. As far as removing the streaks on the sides we finally hired a professional with a buffer and it got rid of most of them. The stubborn ones seemed to fade over time and wash/wax jobs.
If you do a search there are a couple of threads that explain why most of us now use a diluted Dawn solution or Murphys oil soap.
Good luck!
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-28-2016, 10:56 AM   #3
geeman53's Avatar
Spic and Span on rubber roofs .
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 07-28-2016, 11:41 AM   #4
northstar1960's Avatar
So no go with rubbing compound . how about making the rest match the streaks . wash the rv with the roof cleaner and let it dry . then maybe it will all blend in . or keep going at it with rubbing compound try the 3-M compound works great . expensive though
northstar1960 is offline   Reply With Quote
roo, roof
