We run Sailun 235/80/r16 LRG 14 ply tires on our wildcat 5er. I did a lot of research before buying these. They are not China bombs even though made in china. They actually go through rigorous testing. I keep track of the TPMS on our trips. Even here in Florida when the temp gets in the mid 90's the tire temp remains under 100 and the psi never has gone above 122. We really like them. As far as your rims being able to withstand the 110 psi, it should be marked on the rim usually on the inside. I wasn't able to locate mine but the guy that installed them said that they were fine. Look to see if you can find the info on the inside of yours. Good luck.
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
