Old 06-16-2015, 10:03 AM   #1
Schwintec in wall slide
Is anybody else had a problem with
Slide not coming in just at the bottom
On 2014 Crusader 295 5th wheel
Mind just started to not come in on
My last trip to the camp ground . Took it back to dealer I got it from they had
It eight days told me they had never
Seen one doing what it does so here I am with trip planned and slide will not
Come all the way in at bottom I was
Thinking about trading but just about
All the new ones have the same slide
Set up and weak at best ?
Fred Jobe is offline   Reply With Quote
Old 06-16-2015, 10:12 AM   #2
It may be out of sync. Run the slide out and hold the button for an additional 5 seconds after the slide has stopped moving. Do the same when bringing it in. This forces the controller to synchronize each side. Mine is a little out on the bottom as well but that's how they all are, it is pulled tight against the bottom seal and does not leak.
coolzzy is offline   Reply With Quote
Old 06-16-2015, 10:18 AM   #3
Tried that did not help and mind does not come in to seal to
Keep it from leaking that is what I don't like about it.
slide
