Old 03-16-2015, 09:06 PM   #1
Slide out
One side doesnt move when letting out, what might that be?
RUSTYPLOW is offline   Reply With Quote
Old 03-16-2015, 09:10 PM   #2
It's a class c 2014. 319 long, lep.
Old 03-16-2015, 09:10 PM   #3
Rrickim63's Avatar
Please tell us what you have for a camper, is it plugged into shore power? I'm sure someone will chime in
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 03-16-2015, 10:07 PM   #4
Yes it's pluged in shore power. Motor home class c 2014 lep.
Old 03-16-2015, 10:09 PM   #5
One side starts moving when i press the out button. The other end doesnt move so i stop.
Old 03-17-2015, 06:58 AM   #6
geotex1's Avatar
Hello! Not familiar with that C at all but does your slide out have a metal track on each end of the slide out box near the top? If so, you have a Schwintek slide mechanism and one motor is either out of sync with the other or has died.
geotex1 is offline   Reply With Quote
Old 03-17-2015, 07:14 AM   #7
fonzie's Avatar
Which model do you have?
Coachmen RV - Manufacturer of Travel Trailers - Fifth Wheels - Tent Campers - Motorhomes
Fonzie
Old 03-17-2015, 09:22 AM   #8
Just made an appointment to get it fixed, yes, metal track at top. I believe motor is bad on that side. Thanks for the reply. How much motor cost??
Old 03-17-2015, 09:31 AM   #9
geotex1's Avatar
Schwintek motors run between $75 - $225 depending on model at cost for the part. Replacement is easy enough for a tech physically, and then just needs to re-sync them so figure between 1 and 2 hours of labor from a dealer.
Old 03-17-2015, 03:41 PM   #10
Thank you so much for info. I like this forum all ready.
slide, slide out
