07-15-2018, 10:55 AM
Soon to be RV'er
Hello from Vancouver Island! My wife and I have been trailer shopping, and I think we've narrowed it down to a Catalina 243RBS. I've got a 2018 F-150 with the 3.5 Eco Boost and the max tow package, so I'm ready to tow. The dealer should have a 243RBS in next week, and we're going to go and decide for sure. Lots of information (and disinformation?) out there, so lots to learn!
07-15-2018, 11:48 AM
Welcome, good luck with your new RV/TT, every travel trailer has it's on personality and problems, no two are the same. It will take a little time to figure out everything about your new TT. I like the model you have chosen, the only thing that catches my eye is the bedroom door, it opens in front of the entry door, you will always be fighting that door or leave it closed which is not always good for heating and cooling, a slide type door would be better, but not sure it's available on that model. I am not a professional just live full time in our TT, ( travel trailer). Good luck and enjoy your new adventure.
07-17-2018, 10:14 PM
Thanks! We put a hold on a trailer and will sign the paperwork tomorrow. We chose a 2017 Catalina Legacy Edition 263RLS. We really liked the big picture window at the back. Can't wait for the weekend!
07-17-2018, 10:43 PM
Great ,go over it with a fine tooth comb, step on every square inch of floor for soft spots, look in every cabinet for water damage, around every window for water stains, in the ceilings also. Go on top and check for soft spots in the roof. Buying a used trailer you are buying as is, l didn't know anything about travel trailers when l first bought and l missed water damage in the bedroom floor next to the wall as and inside the bedroom closet , travel trailers are not like mobile home, they can have water intrusion in the craziest places. Does this unit have plywood or composite flooring, plywood is best. Is the roof of the trailer a flat roof or does it have a pitched roof , pitched is best , water want stand on the roof . Check real good around the skylight if it has one, for apparent leaks. Used trailers a lot of the time get traded in because of defects or problems, the dealer want tell you, unless you ask, then they don't always. Good luck .
07-17-2018, 11:10 PM
Thanks for all the tips. Even though it's a 2017, it's brand new and hasn't been used. The floor is 5/8" ply. We are getting the full 12 month manufacturer warranty, and we're buying a 6 year extended warranty on top. I usually don't get the extended warranty on things, but this is all new to me and for the price I think it's fair value for peace of mind.
07-17-2018, 11:16 PM
Great, but keep in mind warranties are good, but keep up on all your maintenance, because for what l can see that's the loop hole they use for warranty work. Still go over it as if it was pre-owned , they can still leak and no one has been checking it. Just the most common problem water leaks even on new one's.
07-17-2018, 11:17 PM
Good luck
07-18-2018, 12:20 AM
Just as confused as you
Check everything and take pictures of anything you find that is broken or doesn't work. Don't sign off or give them the check until everything is fixed. Many times once the dealer gets the money your pretty much on your own when it comes to repairs. Other times when you take it in for repairs they will have it for weeks before they look at it. Some members have been without their RV for months.
Richard & Jill
07-18-2018, 07:24 AM
Thanks for the advice, all. Much appreciated.
07-18-2018, 07:43 AM
If you can, wait a year before you buy the warranty, otherwise your 6 year warranty becomes a five year, as the first year they will usually have you use the manufacturer warranty for the first year.
2019 Flagstaff V-Lite 30WFKSV
2021 Chevy Silverado 3500 HD DRW High Country
07-18-2018, 08:19 AM
Nope, not the case with my dealer. It kicks in after the 12 month period, so I have 7 years coverage. If I don't use it, I get 75% of the cost back.
