04-05-2017, 10:03 PM
#41
Originally Posted by Roger D.
Just to do a quick followup:
Bought a new 2016 F-250, Power Stroke, 6.7 diesel, 355 rear end, 440hp, I think it's like 410 fp torque. Maybe this truck will pull my TT Flaggstaff
832-IKBS. .
Good choice! Ford Super Duty is the best truck to replace a Ecoboost, wont be unhappy at all!
04-05-2017, 10:09 PM
#42
Thinking I got it right time. Thanks
HeavyPuller
04-05-2017, 10:18 PM
#43
Originally Posted by Zak1
I own the same truck (2016 supercrew 4x4 short bed 2.7) but with the 3.55 rear end. My trailer is easily 8000 lbs loded. my tow rating is 7500. The 2.7 tows BETTER that all my past trucks for this weight (87 F350 dually diesel, 87 Suburban 454, 99 Dodge Ram, 2006 F 250 diesel) hands down. Key is a very good weight distribution hitch (set up properly) , good trailer brakes (with integrated FORD oem brake controller) and driving sensible. Its funny to read folks with other brand trucks that have never towed with an Ecoboost. The owner of the rv dealer where I bought my TT test drove my truck (with the 2.7) and said it towed as good or better than his personal 2014 F150 (3.5 Ecoboost).
The 2.7 has more power than you will need. the engine is built like a diesel
(heave, reinforce block and heads, Rn in the Baha 1000 (driven from and back to Detroit!)
The EcoBoost is a nice design for sure, however comparing it to a Super Duty diesel is just crazy talk. Saying the 2.7 has more power than you will need is also over the top.
04-05-2017, 10:19 PM
#44
Good choice Roger. 30 years I drove gas trucks. What was I thinking? You will love it. See ya on the road.
Rockwood 8289ws Signature 2016
2016 2500 Hd Duramax
Days camped 2016 30 nights and climbing
Days camped 2017 42 days and climbimg
04-05-2017, 11:26 PM
#45
832-IKBS. .
Your horsepower number is correct but you torque number is not. If I remember right and maybe you pushed the wrong number but I think it's 910 ft lbs of torque.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
04-06-2017, 01:52 AM
#46
Just as confused as you
Roger D.
I'm curious as to what your 832IKBS weighs. Mine is <9000# with 1100# tongue weight. I can pull it with my Silverado 1500 5.3L but I've had it on a seasonal site since I bought it.
Richard & Jill
04-06-2017, 06:43 AM
#47
Originally Posted by Scrapper
Roger D.
Dry wt 8,140 and hitch wt 1,110.
HeavyPuller
04-06-2017, 08:08 AM
#48
My 2011 Ford F-150 with the ECO boost and full tow package is rated at 11,300 lbs. Rating is like 10,500 with the V-8 gas engine.
04-06-2017, 08:25 AM
#49
Tom
Travel Trailer Towing 101: You cannot tow anywhere close to the rating without exceeding other limits.
04-06-2017, 08:36 AM
#50
Towing Axiom 101(b).....if your entire setup as fully loaded has cargo carrying capacity (called "payload") to spare, all other towing specification numbers will almost always work. The reverse is not always true.
FROG AR-0019-242
04-06-2017, 08:46 AM
#51
You're right - wrong key, thanks. .
HeavyPuller
04-06-2017, 06:12 PM
#52
Tom
That is why I used Travel Trailer Towing 101 instead of Towing 101 to rule out the hypothetical axiom.
04-08-2017, 06:41 PM
#53
Agreed. Best to keep dry weight under 50% of tow capacity. This usually keeps you under all of the various limits.
My ecoboost has no issues with my 5,000 lb trailer.
04-08-2017, 10:03 PM
#54
My 3.5 Ecoboost 3.73 max tow can do 11200 but I would not tow near that rating our trailer is about 850 tongue weight and about 8500 down the road. Easily tows this .
ADKDAN
04-09-2017, 08:16 AM
#55
Absolutely a better choice. I am more comfortable on the road knowing an HD truck is pulling that weight.
04-09-2017, 08:48 AM
#56
If the 11200 lbs is from the Ford Towing guide or other charts that is a best case with a lightly optioned truck. The only way to determine the maximum towing capability of a given truck is to run the calculations. typically it is payload that folks run out of first and becomes the limiting factor in TT or 5th wheel weight you can tow. You still have to consider all of the other maximum weights though as you could have enough payload but be over the other ratings.
04-14-2017, 07:28 AM
#57
Wounder if any longtime rv'ers have any first hand information on this: I have a 2015 Ford XLT, 4 x 4 EcoBoost with a 2.7 liter engine with twin turbo's, 325 horsepower, automatic 6 speed. Crew-cab (not a true 4 door) has a towing package and rated at 12,500 pounds tow rating.
QUESTION IS: Do you think a
832-IKBS, FlagStaff (GulfStream) that dry weights at 8,100-+ and tough wt of 900lbs will be TO much weight for the small 2.7 V6, 2015 Ford XLT, EcoBoost. It has a 6 foot bed. I know the book says it's tow rating is 12,500 pounds. But seems to be an awful small engine for that size travel trailer at 35 feet.
check this out....
http://www.forestriverforums.com/for...ck-123619.html
