Old 05-02-2013, 09:54 AM   #1
Tow Vehicle
Will my Silverado 2500hd with Duramax Diesel tow a Columbus F320RS?
mxs591014 is offline   Reply With Quote
Old 05-02-2013, 10:02 AM   #2
TURBS's Avatar
I wouldn't but that's just me.
Pin weight is over 2000 lbs dry
You didn't mention the year of tv but 2448 is around max ccc for an 08 ext cab std box.
Old 05-02-2013, 10:13 AM   #3
Fulltime family RVer
Maybe, maybe not. As turbo said - it all comes down to pin weight and your truck's ratings (and, if you're willing to exceed some of them or not).
See if this write-up helps:
Learn To RV: What Can I Tow?
Old 05-02-2013, 12:19 PM   #4
semi-senior member
denandra2's Avatar
Seems to be a lot of folks doing it!!!! Will 75lbs make that much difference?
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
Old 05-02-2013, 12:22 PM   #5
TURBS's Avatar
Either they have no clue.
Or they think they have a clue and still dont care.
Old 05-02-2013, 12:36 PM   #6
Sure it will, but will you be legal? That's the big question no one can agree upon around here
If I decide to upgrade, I will have the same question for my F250.
Len & Cheri is offline   Reply With Quote
Old 05-02-2013, 12:37 PM   #7
Denver, CO
garbonz's Avatar
My experience with a similar rig, weight wise is that you can do it, if you beef up the rear a bit and carry NOTHING in the truck. BUT it is a bit to much. I went smaller and lighter and happier.
If you really need a unit that big, and can't get the right tow vehicle then you can do it, but better hope you don't get stopped or have to stop it in a short space.
As said here, many do do it.
2017 Fuse 23T
Old 05-02-2013, 01:37 PM   #8
Camper Less Camping
Cajun Po-Boy's Avatar
FIRST:
Do the math on your truck's capabilities-great starting point on what the manufacturer states the truck can handle (math don't lie).
SECOND:
Checkout the GVWR of the desired camper and it's pin weight & compare to your truck's capability numbers to these. (pin weight # will increase when loaded)
THIRD:
At the end of the day, it's your choice...am I concerned with being legal or getting what I want/desire without upgrading truck or downsizing camper.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
