Old 09-21-2015, 10:33 AM   #1
Very little hot water?
Have been camping 2 times in our new 2015 Cherokee Grey Wolf 23bd, we have "pee" warm water ,have been using only electric, should we use the propane to run it on? It is a 6gal. water heater. Any suggestions would be great!!!!!!
kwoody79
krwoody79 is offline   Reply With Quote
Old 09-21-2015, 10:45 AM   #2
nomad297's Avatar
Your water heater bypass valve is in the bypass position and the hot water valve is in the on position. Turn off the bypass valve and everything will work fine.
Bruce
nomad297 is online now   Reply With Quote
Old 09-21-2015, 10:47 AM   #3
DaveSchwartz's Avatar
Hot water recovery rates are lower with electric (and you can't tell when its up to temp as easily as when the gas shuts off) so the time from initial fill to full hot will be longer.
Also check your winterizing valves at the back of the WH - you should have been shown where these are during the walkthrough. All trailers shipped to locations where where winters go below freezing are shipped winterized (they can't tell how long its going to sit on a dealer's lot). In winterize position, the oval handle on the bypass valve (the one that runs between the hot and cold) is in-line with the pipe (and the hot and cold on the individual lines closer to the WH are perpendicular). In operating position they should all be 90 degrees from that. Leaving the bypass in winterize mode is a common issue causing lukewarm (or variable temp) water for newbies with new trailers.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-21-2015, 10:47 AM   #4
TURBS's Avatar
Bruce
I agree.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
hot water, water
