Old 01-20-2013, 07:07 PM   #1
Water Heater switch
Anyone know if the electric water heater element is automatic. Can't find the switch. I notice water is hot when hooked up to power. Also what is tank heater for ?
kburks is offline   Reply With Quote
Old 01-20-2013, 07:13 PM   #2
jtstromsburg's Avatar
More info on your camper will help, but no, i do not believe the electric side of your water heater would be automatic. If you leave it on all the time, and drain it (either through its drain or by running out of water) you will burn the element up. There may be a small switch under the outside cover to turn it off.
The tank heater switch is most likely to turn on the pad heaters on your black, grey, and fresh water tanks to help prevent freezing in cold weather.
Btw, welcome To the forum !
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 01-20-2013, 07:39 PM   #3
TURBS's Avatar
On off switch should be located at the hw tank outside.
Lower left corner when u open the door if is a suburban.
Turbs
Old 01-20-2013, 07:45 PM   #4
TURBS's Avatar
Old 01-20-2013, 08:19 PM   #5
Ours cannot be seen while standing up: You have to kneel down on the ground and look up.
flaggy is offline   Reply With Quote
Old 01-20-2013, 10:02 PM   #6
bikendan's Avatar
kburks, it's always helpful if you post year, brand and model of RV.
and brand and model # of WH.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
