Old 06-09-2016, 08:36 PM   #1
Water pump over fill
Hello all,
We have a 2014 sunseeker 3170 ds. I pulled into Rv site, and started to hook everything up as usual. I hooked up the water line to the city water hook up, water pump off. The next morning, we had water coming out the fresh water hook up. We turned off water and then noticed water under the bed compartment. Any suggestions what would cause this?
I now have to use pump for water out if fresh water tank.
Thank you for help.
Dakotablue is offline   Reply With Quote
Old 06-09-2016, 08:43 PM   #2
Blackrock's Avatar
Higher water pressure at the park can override the check valve at the pump causing it to backfeed to the FW tank. Happened to me at the SIlver City, NM KOA even with the cheapy WP regulator.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 06-09-2016, 08:43 PM   #3
Left Coast
Check valve in pump stuck open....got A regulator?
Old 06-09-2016, 08:44 PM   #4
Who Dares, Wins
doc73's Avatar
Check valves also stick sometimes.
Sent from my SM-G930V using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-10-2016, 04:08 AM   #5
Thanks for help. I have a two year old reg , should I change it? Guess that is a cheap fix. Oh and is the valve in the pump?
Old 06-10-2016, 04:17 AM   #6
Witch Doctor's Avatar
You might not need to change it yet, It has happened a couple times to me, what I did was turned off the city water and just used the pump. After awhile turn the pump off and rehook up your city water. If the diaphragm went it will fill your fresh water tank again. Also clean the little bowl with the screen in it attached to the pump. They sell a kit to replace the diaphragm, but IMO it is better just to buy a new pump....
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 06-11-2016, 06:55 AM   #7
Tjanks for help I will try this this weekend
Old 06-11-2016, 06:56 AM   #8
Hello all,
Thank you for help.
Thank you all for help I will on it this weekend and let you know how it goes!!
Old 06-12-2016, 05:37 PM   #9
After some friends told me of the problems they had with cheap bullet type regulators... I purchased and installed a Watts home water pressure regulator in my hose line setup. set the pressure at 60 psi and never had any trouble, well worth the few extra dollars for the Watts.
Boohiney is offline   Reply With Quote
Old 06-12-2016, 05:51 PM   #10
m2kamp's Avatar
This fixed my back fill problem:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
$7 shipped through my amazon Prime. Installed between my pump and the tank line in less than 5 minutes, simply unscrew line from pump and screw this in place between line and pump.
Beats open/messing with the failed pump internal check valve.
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
pump, water, water pump
