Old 07-08-2016, 08:54 PM   #11
MrNiceGuy's Avatar
Dometic Comfort Control Center 2 (CCC2) E1 Error Recovery When “E1” appears on a CCC2 display (as shown below) for one or more Zones, follow these steps to correct this error: Zone 1 2 F AM LO 1. First, reset the CCC2 using the Dometic “System Reset Procedure” (see NOTE below): • Press OFF . • Press ZONE and MODE at the same time. The CCC2 screen will display the “IniT” screen which will list all the available Zones: Zone 1 2 2 F AM LO • Release ZONE and MODE. • Press OFF . 2. If all the available Zones do NOT appear on the “IniT” screen, do the following: • Disconnect all 120VAC and 12V power for 20 minutes. • Repeat the “System Reset Procedure”. NOTE: “System Reset Procedure” from Dometic Comfort Control Center 2 Thermostat Operating
2015 Crusader 315RST
2011 Silverado 2500HD
MrNiceGuy is offline   Reply With Quote
Old 07-08-2016, 08:57 PM   #12
MrNiceGuy's Avatar
I was hoping to get you some info on the E1 error but the formatting turned out lousy. Sorry. If you have an internet connection and the ability to do a google search on the error it appears to be a common issue. Good luck!
Old 07-08-2016, 09:44 PM   #13
Jlreeves's Avatar
I tried a procedure pretty close but didn't wait 20 mins. Will try it tomorrow. Thx for info.
2017 PrimeTime Crusader 315RST 5th Wheel
2014 Chevrolet Silverado 2500 HD
2002 Thor Chateau Sport Class C
Good SAM # 807510227
FROG # GA-0056-236
Jlreeves is offline   Reply With Quote
Old 07-09-2016, 04:55 AM   #14
CarpeDiem's Avatar
Welcome from South Carolina! Sorry you're having trouble, best of luck!
2016 Grey Wolf 24RK
2014 Nissan Titan
Always do whats right; this will gratify some and astonish the rest Albert Einstein
CarpeDiem is offline   Reply With Quote
Old 07-09-2016, 06:20 AM   #15
Jlreeves's Avatar
Originally Posted by Silverado2500HD View Post
Welcome! We are owners of a 2015 Prime Time Crusader 315RST also. And by the way our tow vehicle is a 2011 Silverado 2500 HD.
The trailer towed great. Truck seemed well matched and with a few adjustments it will be like its not even back there, well sort of...
FROG # GA-0056-236
Old 07-09-2016, 07:00 AM   #16
Usually Confused Member
emm-dee's Avatar
I've never seen the E-1 code so this might not apply. Read another post on the forum that said the thermostat would act up if it saw a temperature of 99 degrees. The solution was to surround it with an ice bag to fool it enough to get the a/c running.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-09-2016, 03:55 PM   #17
Jlreeves's Avatar
Tried this today allowing 25 mins off of power with no change. Called dealer service and ran field service diagnostics which show the circuit board in thermostat is fried. Back to dealer for repair on Monday. Ah well, that's how it goes.
FROG # GA-0056-236
Old 07-09-2016, 06:07 PM   #18
MrNiceGuy's Avatar
Wish it could have been something a little easier to have repaired. Hopefully some great times very soon!
Old 07-14-2016, 09:48 PM   #19
Jlreeves's Avatar
Ok. Trying again. AC working so far. Had first meal on board. Fingers crossed.
FROG # GA-0056-236
Old 07-15-2016, 06:46 AM   #20
Georgia Frog Rally 2017
aceinspp's Avatar
Welcome to the forum. Glade to hear your ac is up and running. I'll be having a rally in Helen GA next year love to have ya come. It's posted under Frog rallys. La
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
