06-30-2016, 06:59 AM
Welcome from N GA
Welcome from Roswell GA. We just bought a 2017 PrimeTime Crusader 315RST. It is our first 5th wheel but our third camper. We have had two other class Cs before. Looking forward to picking it up next Friday and taking a short shakedown trip. See you all around.
2017 PrimeTime Crusader 315RST Fifth Wheel
2014 Chevrolet Silverado 2500HD
06-30-2016, 07:41 AM
Welcome!
Glad to have you aboard!
"But, oh that magic feeling, nowhere to go." -- The Beatles
2015 Flagstaff 8528RKWS fiver
2013 Ram 2500 CTD Laramie CC SB 4WD Auto
06-30-2016, 12:30 PM
Welcome to the forums from SoCal! Enjoy your shakedown trip.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
06-30-2016, 07:47 PM
Citrus County, Fl.
Welcome from Central Florida. Hope you enjoy many nights in you new 5er.
If you are interested, there is a FROG rally coming up in Sept. in Williston Fl. and another in Gadsden, Al. in Oct. You can find them on the forum
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
06-30-2016, 08:05 PM
When No RV, Ford in Tow.
Welcome aboard fro NJ!!
Ride like the wind, don't break it!
06-30-2016, 08:29 PM
Welcome! We are owners of a 2015 Prime Time Crusader 315RST also. And by the way our tow vehicle is a 2011 Silverado 2500 HD.
2015 Crusader 315RST
2011 Silverado 2500HD
06-30-2016, 09:59 PM
Welcome from Wisconsin and congrats on your 2017 PrimeTime Crusader 315RST.
07-08-2016, 07:59 PM
Well, this hasn't gone well. Just after getting set up the Dometic thermostat showed an E1 error and neither unit will run. 96F here. Too hot to continue.
2015 FR3 30DS Motorhome
2017 PrimeTime Crusader 315RST 5th Wheel
2002 Thor Chateau Sport Class C
Good SAM # 807510227
FROG # GA-0056-236
FMCA # F471293
07-08-2016, 08:20 PM
[QUOTE=Jlreeves;1252714]Well, this hasn't gone well. Just after getting set up the Dometic thermostat showed an E1 error and neither unit will run. 96F here. Too hot to continue.
At least it was a shakedown trip. The first thing I do when I have a problem is shut it down. Every now and then it works. Disconnect all your power to include the battery and try again. You may be lucky. And welcome from Stone Mountain, GA.
2021 Silverado RST Z71 4x4 6.2L
2021 Flagstaff Micro Lite 25FKS
USMC (Retired) '70-91
07-08-2016, 08:43 PM
[QUOTE=aufinger;1252740]
Thanks for advice. Already tried it. Thermostat shows same. We are bailing. 30 miles from home so we will start over tomorrow.
FROG # GA-0056-236
FMCA # F471293
07-08-2016, 08:54 PM
Dometic Comfort Control Center 2 (CCC2) E1 Error Recovery When “E1” appears on a CCC2 display (as shown below) for one or more Zones, follow these steps to correct this error: Zone 1 2 °F AM LO 1. First, reset the CCC2 using the Dometic “System Reset Procedure” (see NOTE below): • Press OFF . • Press ZONE and MODE at the same time. The CCC2 screen will display the “IniT” screen which will list all the available Zones: Zone 1 2 2 °F AM LO • Release ZONE and MODE. • Press OFF . 2. If all the available Zones do NOT appear on the “IniT” screen, do the following: • Disconnect all 120VAC and 12V power for 20 minutes. • Repeat the “System Reset Procedure”. NOTE: “System Reset Procedure” from Dometic Comfort Control Center 2 Thermostat Operating
07-08-2016, 08:57 PM
I was hoping to get you some info on the E1 error but the formatting turned out lousy. Sorry. If you have an internet connection and the ability to do a google search on the error it appears to be a common issue. Good luck!
07-08-2016, 09:44 PM
I tried a procedure pretty close but didn't wait 20 mins. Will try it tomorrow. Thx for info.
FROG # GA-0056-236
FMCA # F471293
07-09-2016, 04:55 AM
Welcome from South Carolina! Sorry you're having trouble, best of luck!
2018 Rockwood Premier 2516G
2014 Nissan Titan
“Always do what’s right; this will gratify some and astonish the rest” – Albert Einstein
07-09-2016, 06:20 AM
The trailer towed great. Truck seemed well matched and with a few adjustments it will be like its not even back there, well sort of...
FROG # GA-0056-236
FMCA # F471293
07-09-2016, 07:00 AM
I've never seen the E-1 code so this might not apply. Read another post on the forum that said the thermostat would act up if it saw a temperature of 99 degrees. The solution was to surround it with an ice bag to fool it enough to get the a/c running.
BIRDS AREN’T REAL
07-09-2016, 03:55 PM
Tried this today allowing 25 mins off of power with no change. Called dealer service and ran field service diagnostics which show the circuit board in thermostat is fried. Back to dealer for repair on Monday. Ah well, that's how it goes.
FROG # GA-0056-236
FMCA # F471293
07-09-2016, 06:07 PM
Wish it could have been something a little easier to have repaired. Hopefully some great times very soon!
07-14-2016, 09:48 PM
Ok. Trying again. AC working so far. Had first meal on board. Fingers crossed.
FROG # GA-0056-236
FMCA # F471293
07-15-2016, 06:46 AM
Georgia Rally Coordinator
Welcome to the forum. Glade to hear your ac is up and running. I'll be having a rally in Helen GA next year love to have ya come. It's posted under Frog rallys. La
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
