Old 06-05-2017, 12:40 PM   #1
Question Leveling Jacks - Checking fluid
Where is the hydraulic fluid level check for the leveling jacks?
New to the forum and new owner of 2000 Reflection 350 class A diesel. Rear leveling jacks are not retracting. Prior to them stopping I was spraying them with a teflon spray to try and loosen them up, no joy. I can retract with a 2x4 & slight pressure. Springs are pretty worn to. Before replacing the springs I want to check the hydraulic fluid level to see if it is low. Can find the reservoir, does anyone know where it is located?
rtmueller is offline   Reply With Quote
check, jacks, leveling
