Old 06-14-2016, 02:31 AM   #1
Wiring diagram for batteries, inverter, relay transfer, and breaker box
I'm hoping someone out there might have a 2000 Reflection by Forest River Diesel motor home and could take some picks of these items above. Bought motor home seemed to be in great condition but having terrible electrical issues!! Any help would be greatly appreciated!!
Thanks in advance DJ Terry
Email pics: djdrlgoilgas@gmail.com
djdrlgoilgas is offline   Reply With Quote
Old 06-17-2016, 12:29 PM   #2
No one with a reflection motor home
Old 06-17-2016, 12:41 PM   #3
Most likely never going to find a wiring diagram. It might help if you were specific with your problems.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 06-17-2016, 12:53 PM   #4
Herk7769's Avatar
Looks a lot like a Georgetown.
If you think that might help, there is a wiring diagram for the 30DS floating around.
HAM CALLSIGN - KC3FFW
Old 06-19-2016, 04:58 PM   #5
Thank you where could I find the George Town diagram
Old 07-10-2016, 03:50 AM   #6
I also have a 2000 327S Reflection Diesel Pusher am in need of a wiring diagram on where to put the wires on the batteries, I thought I would remember when I was removing them but that turns out not to be the case.
Dishmand is offline   Reply With Quote
Old 07-10-2016, 05:01 AM   #7
ilmor's Avatar
How many batteries does it have, what voltage and how are they arranged in the bay? Starting there someone can come up with a diagram for you.
For example:
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-10-2016, 06:56 AM   #8
For example:
I have four 12V Batteries. Two House batteries in parallel, and two cranking batteries in parallel, I know where the large cables go but am confused where all of the small wires go that are connected to the house batteries. Thanks, Dee
Old 07-10-2016, 08:40 AM   #9
Generally the "small wires" are loads that are not cut by a disconnect switch. This includes propane detector, stairs and potentially some others. Generally all of these loads already are connected to the common chassis ground and the rest of them go to the positive connection on the house bank (either one since I assume there is a heavy gauge wire that connects the two together.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 07-10-2016, 06:12 PM   #10
I wish mine were connected to a common chassis ground as that would have simplified this problem that I created, then I would only have to hook up to the positive terminal on the house batteries with the small wires that I had left. I guess I'm gonna have to trace where every wire goes to.
Thanks Dee.
breaker, diagram, inverter, wiring, battery
