Old 09-17-2015, 08:48 AM   #11
A few simple rules driving in winter in the "true" N.E. USA. Pick your times, by that I mean if a snow storm is classified by the weather service as an advisory, snow covered roads may not materialize. If the storm is elevated to a warning in the area you will be, or are driving into, that means snow is eminent. So, in that case you need to stay put till it clears. I'll assume your not climbing steep grades, where the road class is anything less than most improved on your trip. Remember, we all still go to school, work, ski, etc. so you southern softies will get a chance to see a true NH winter wonderland.
Seriously, I would call the perspective campgrounds you plan on staying at, and talk to a body, knowledgeable if possible, to make sure they will be open. All public campgrounds would be closed in winter in the north, so you must mean private sites. Just sayin'
Old 09-17-2015, 08:51 AM   #12
Who Dares, Wins
doc73's Avatar
Even many of the private sights will be closed. Many up here close by October, maybe November
Sent from my SAMSUNG-SM-G870A using Tapatalk
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 09-17-2015, 08:55 AM   #13
EastlakeRoo's Avatar
Like others have stated. Weather is hit or miss and can change daily. I guess plan for just above temps to freezing temps especially in Jan. and Feb. with possible snow white outs. Like others have stated, most CG's close mid October and don't reopen till April-May timeframe. Call ahead and verify if your CG's are open regardless of weather conditions just so you aren't pulling in and no-one is there.
You should get familiar with your water system to see how long and what it takes to winterize if weather conditions should change from semi-temps to freezing for several days.
Would also make sure all propane tanks are topped off and heater is functioning properly in Motor Home before leaving. Nothing like traveling and find out mid-way the system doesn't work or you ran out of propane. Just about any flying j I think has propane available but I rather leave when everying is topped off and ready.
Just my 2 cents. Wishing you safe travels and good time visiting family...
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 09-17-2015, 08:59 AM   #14
B and B's Avatar
In Ontario we have several Provincial Parks open. Fully Heated washrooms and showers. They plow the sites at Pinery for trailers. You can fill up with water at the washroom and have electric. We plan on going this year between Christmas and New Years ourselves.
We have tank heaters. Important is not to be miser and actually use the furnace, this heats the underbelly and storage areas. If you use electric heaters and no air flow you are looking for trouble with frozen pipes.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 09-17-2015, 09:04 AM   #15
KMP44's Avatar
Originally Posted by vminchew View Post
What can we expect from the Interstates?
Salt - and plenty of it. The chances of getting all the way to NH without encountering any snowy, sloppy roads is pretty slim that time of year. Plan on washing a ton of dirty slush off your rig, and the salt won't do the underside any favors either...
And I would consider winterizing the plumbing. The handful of campgrounds I know off in northern NY that are open (for snowmobilers mostly) turn off their water systems. Bathhouses have water, but no water to the sites or dump station availability. Its liable to be well below freezing that time of year. An "artic package" is fine when its 20 degrees. I wouldn't trust it not to freeze at zero for extended periods, which is a possibility in January.
Personally, I would get a hotel - or when we camp in January, its at a campground, but in a heated cabin with running water. Much easier and way more comfortable.
2005 F-150 FX4
2013 Rockwood Roo 23 IKSS
KMP44 is online now   Reply With Quote
Old 09-17-2015, 09:36 AM   #16
Until the Great Lakes freeze, early February, you can expect lots of snow blowing down through NE Ohio through PA and into Virginia periodically. Water is picked up from the open lake water, freezes then dumps further South. Though the DOT does a great job with the interstates, when I had to commute in NE Ohio, there were times when a storm came in overnight, and snow was up to my hub caps trying to get home in the morn. It is probably the worst time of year to get through those states you mentioned.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-17-2015, 10:16 AM   #17
I've lived in the western lake erie rust belt my whole life,and you will never get the salt out of all the joints and seams of your rig.It will stay there no matter how much you wash it and every time it gets wet it will rust and corrode more.You wont see it untill its done its work.If you are planning to sell the class a next summer,go for it,otherwise,use a different mode of transport to get up there.
trbomax is online now   Reply With Quote
Old 09-17-2015, 10:26 AM   #18
Lots of good advice. But I think the best question to ask yourselves is who in their right mind goes North in the Winter?
B47 is online now   Reply With Quote
Old 09-17-2015, 10:34 AM   #19
But, he is going to New Hampshire.
Old 09-17-2015, 12:42 PM   #20
Jim34RL's Avatar
Like other's have said it is winter and this is different than a winter in AK. Also when a Nor'easter is forecasted leave immediately, this is like a hurricane but it is a winter storm. Wind's and blowing snow can accumulate quite quickly mainly in the Massachusetts and Maine area.
If your rig has tank heaters use them but make sure fluid like water is them first. When pulling into a campground make sure your rig is full of fuel, so this way if you have to start the motorhome you will have fuel to run the engine.
Good luck!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67
