Pedestal means the place where you plug in your shore line. 50 amp service is actually two 110 volt lines through a dual breaker where you plug in. There is also a master breaker on each phase in the RV park that could be tripped. Ask neighbors if they also have lost some power. Besides a popped GFI, individual outlets may have the input on one set of screws and then pass to the next from the other two screws. I have had a loose connection half way from source to end of the chain. The outlet at that point worked but nothing further on.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
