Originally Posted by Stovebolt
Speaking of batteries, does anyone out there keep their trailer plugged into the vehicle overnight? Scenario I'm thinking of is having everything hooked up the night before and then take off early in the morning. As far as any battery drain, the truck should charge the TT battery while traveling.
The problem is you will be draining the truck battery all night. It may discharge the truck too low and then your truck won't start. It only takes a few seconds to plug the cord in so why take the chance?
If your worried about forgetting to plug it in stick a note on your steering wheel to remind you. I keep a small tablet there with reminders of things to check before I pull out. The thing I forget the most? Putting the trailer steps up.
Jim
