Old 04-11-2011, 09:40 PM   #1
1141 vs 1156 bulb....what's the difference?
as i was taking apart my exterior light assemblies to check which bulbs i had, i noticed that the clear lamps in the rear (shining on by my rear door {toy hauler}) were an 1156 bulb. then when i checked the bulb behind the amber lens above the main entrance door it had an 1141. the bulbs look the same, and the 1156 works in the 1141 housing........so whats the difference? can i order an 1156 automotive LED light and use it? something like this.... http://www.dingjuled.com/UploadFiles...2512_49606.jpg
also, i see that my interior light assemblies use this 1141 bulb. can i used these automotive type bulbs in these as well? they are considerably cheaper than this type of bulb 200 Lumes 12V LED interior lighting RV and Trailer | eBay
2006 Cherokee Wolfpack 295WP - 2 Interstate U2200 6v, 1500w inverter, clear lens LED clearance and tails, Starlight Revolution 300 lumen LEDs EVERYWHERE!
2012 Dodge 2500 - deleted and tuned by H&S performance
Bocephus is offline   Reply With Quote
Old 04-11-2011, 09:50 PM   #2
sherdep's Avatar
Here is the diffrence
1141 Headlight, Spot Single Element/1-Contact, 12 Volt, 21 Candle power, Standard size 2-pin base, pins directly across, 1 15/16"
1156 Bright Bulb, 12 Volt, 35W, Single Element, light blue glass, bright white light, ( 2-pack), Standard size 2-pin base, pins directly across, 1 15/16" tall.
looks like the 1156 is brighter
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-11-2011, 09:57 PM   #3
caper's Avatar
The 1156 is brighter and will burn hotter. Could cause problems with lense melting.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-11-2011, 10:02 PM   #4
but if i go with LED bulbs, they are not supposed to burn hot.....
Old 04-12-2011, 10:44 AM   #5
I installed an 1156 equivalent LED bulb in my porch bug light (orig 1141 like yours) and ran it all this past weekend with no issues. Believe me, I *tried* to melt the lens housing.
Can't speak to interiors since I have 921's but I would think you would be OK.
45 ACP is offline   Reply With Quote
Old 04-12-2011, 03:56 PM   #6
do you have a clear or yellow lens? what color bulb did you use?
Old 04-13-2011, 12:58 AM   #7
Yellow lens and I use the "standard" white color. Same thing for the curb/roadside lights with clear lenses.
Inside, I use "Warm White" to offset the blueish tint of "standard" white LEDs.
Old 04-13-2011, 05:44 AM   #8
i'm sure i will end up using the yellow lens with white bulb like you did. but since those lenses are cheep and the bulbs are not much more, i ordered a clear lens with and yellow bulb. im not sure if that will make it too bright and attract bugs or not. i definitely think it will look better with the clear lens vs the yellow lens. it will tie in quite nice with my clear lens clearance light assemblies
