Old 06-10-2016, 12:59 PM   #11
Evereddie's Avatar
Could be you let your battery drain low and the converter is working real hard to charge them up causing the hum and 60 cycle getting into the charging voltage. Test it after it has charged for a day or two. Also test with the shore power un-plugged. .
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 06-10-2016, 01:19 PM   #12
Left Coast
The mini controllers are good for 5 to 24 volts...
Old 06-10-2016, 01:32 PM   #13
HONDAMAN174's Avatar
Many of the led strips are 9-24 volts also
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 06-11-2016, 11:31 AM   #14
Humming noise-fan?
Kuba is offline   Reply With Quote
Old 06-13-2016, 10:36 AM   #15
Battery has been charged for days. Literally when I plug in the trailer, the led strip turns green and does not return/cannot be changed with remote unless I unplug the trailer from power and run power off the charged battery.
I've decided to order a few new IR remote controllers to see if the issue is with the controller.
DavinG is offline   Reply With Quote
Old 06-13-2016, 11:10 AM   #16
Evereddie's Avatar
It is either the higher voltage while plugged in doing this, or you have some device in the trailer that is putting out RF interference, or the charger(converter) is doing this. Good move at this point to try a new controller.
2018:16
Total 239
led, power
