Old 03-23-2015, 10:16 PM   #1
farmncamp's Avatar
2 Gallon Accumulator install
I've spent much of the winter planning upgrades to my Coachman 360IBL. Spring is somewhat here, so its time to start the mods.
On occasion, our water pump would cycle - even with no water being used. I looked everywhere I could find for the leak, but was unable to locate it. Since it would only cycle every 5 hours or so with no usage, I opted to get an accumulator. In the process of installing I found the leak!
Step 1: Remove the wall in the garage.
Step 2: Make mount for tank
Step 3: Mount tank & Add Fittings
Step 4: Finished Product
ID:	72056   Click image for larger version
ID:	72057   Click image for larger version
ID:	72058   Click image for larger version
farmncamp is offline   Reply With Quote
Old 03-23-2015, 10:28 PM   #2
B and B's Avatar
Nice install and great idea!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 03-23-2015, 11:37 PM   #3
I purchased a 2.5 Gal Stainless accumulator for my TT and it works beautifully. Long time between cycles on pump now. Your handiwork looks fabulous!
Zolin is offline   Reply With Quote
Old 03-24-2015, 06:44 AM   #4
TURBS's Avatar
I'll be working on a similar modification this spring on my sabre.
I've had the parts since last year and never got to it.
Thanks for the pics.
Old 03-24-2015, 06:59 AM   #5
I did this mod 3 years ago and it was the best upgrade I've done. You can flush the toilet at night and not wake everyone up and on the road you don't need to leave the pump on to use the toilet 3 or 4 times.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-24-2015, 07:24 AM   #6
RPAspey's Avatar
Nice job. One question though, what is your plans to winterize? I mounted my accumulator vertical so water would naturally drain, but would have like to mount it horizontally like yours.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 03-24-2015, 07:33 AM   #7
TURBS's Avatar
Good question.
Mine was designed with winterizing in mind "vertically" .
Also going to mount on the the back basement wall.
Old 03-24-2015, 08:02 AM   #8
Witch Doctor's Avatar
Well I know you live where you have to winterize how did you design that in, Or do you spend your winters in the South?
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-24-2015, 08:04 AM   #9
The tanks are normally mounted vertical so they automatically drain.
Old 03-24-2015, 08:24 AM   #10
Hor or Vert. makes No difference,the internal Bladder has air/no2 behind it that allows for Movement! Turn on any outlet and allow to drain water pressure,then shut Off the valve to Acc.ready for winter! This only readys the ACC.go thru your Normal Winterizing! Youroo!!
