05-02-2012, 11:43 PM
2005 silverado towing mirror install.
Today I got my towing mirrors from eBay My World - am-autoparts for 159.45 and free shipping . I ordered them on 5-1-12 before noon and received them on 5-2-12 ! One day shipping !
these are stock photos
My truck happens to have power mirror and heated mirror which these replacements are as well . The replacements are manual pull out for towing .
If your truck mirrors have an oem blinker in them you can get those as well .
In the next few posts I will show you how easy these are to install on a 2003-2007 silverado 2500 hd A gmc would be the same .
05-02-2012, 11:57 PM
tool list includes
medium flat screw driver
t15 torks screw driver
1/4 ratchet
1/4 long extension
1/4 7mm socket
1/4 10 mm socket
first remove plastic triangle piece flat screwdriver on a corner pops it off.
this will show mirror mounting nuts after you remove foam.
then pop off door lock bevel from the back with screw driver.
this reveals a 7mm bolt take this out
then just under door grab handle is another 7mm bolt take it out.
05-03-2012, 12:08 AM
Next remove door handle bezel from back shown here .
Next on the very bottom of door there is a torx screw to take out to remove your tray . shown here .
Next at the front of the door is a push tab holder known by some as a christmas tree . Pop that out with a screw driver .
Then towards the back of the door is a screw cover . Pop that off to revel another torx screw . Go ahead and remove that .
05-03-2012, 12:15 AM
Lift panel up and pull away from door . Hold on to panel while you follow wire down from mirror and disconnect from holder. left mirror has one connector right mirror has two. then remove the three nuts that hold mirror on with a 10 mm socket .
Install new mirror and everything else in reverse order .
This whole mirror install takes 15 minutes per side half hour total .
I recommend these mirrors !
These new mirrors extend a full 4 inches and do swing in like the oems .
plus they have a convex mirror in the bottom on both sides.
05-03-2012, 12:18 AM
oem mirrors .
05-03-2012, 09:13 AM
Mod free 5er
Nice job f1100turbo with the instructions and pictures. I was lucky 3 yrs ago and got a set of power towing mirror OEM on ebay for $150. They have the turn signals, power extend but not heated. Because of the power extend, I took them to a Chevy dealer in Deland, FL and they installed them and also threw in a wash job for $100. They had to supposedly reprogram the computer to make the power extend work. To extend them requires putting the l-r switch in the center and press the outside tilt button and the right tilt button to retract. Very handy, but I do wish they had the big convex mirror on the bottom that could be power adjusted separately. DW says I'm never satisfied.
BTW, I still have the original std power mirrors if anyone is interested, just pm me.
05-03-2012, 09:22 AM
You got lucky! Oem power mirrors sell for 350.0 each new
4 to 5 hundy new!
Any aftermatket or new upgrade from stock has to be programmed into computer
but all are prewired just not "applied " in body module.
05-03-2012, 11:27 AM
F1100turbo
I have '03 silverado with power/heat/signal/auto dim in mirror so far everything seems to work OK for you? You mentioned needing to program the aftermarket mirrors with truck computer did you do this or they working fine with out reprogramming love to add "same options" to my truck if it isn't too much trouble BTW $159 each or for the pair? thanks
05-03-2012, 12:16 PM
I put trailer mirrors on my '06 silverado, which had power folding, heated, signal mirrors on it. Only had to pop off small triangular inside cover and remove 3 nuts on each mirror and disconnect plugs. Had both mirrors on in under 10 minutes.
05-03-2012, 08:28 PM
Originally Posted by Hambonethecop
F1100turbo
you only have to program them if say your oem didnt have blinkers in the mirror and you got an aftermarket set with a blinker .
if your already had a blinker your fine .
now my oem didn't have a blinker and neither does the aftermarket 159.00
259.00 i think with blinker il check
here is one with a with blinker http://www.ebay.com/itm/CHEVY-SILVER...ht_5180wt_1141
here is the one I would suggest . http://www.ebay.com/itm/03-06-Silver...ht_2718wt_1025
I think the only thing the oem mirrors DO NOT do is tilt down for park assist .
05-03-2012, 08:44 PM
use the compatibility finder to make sure it fits your truck there is many differences .
hd or non hd
I drove my tv to work today to check out the mirrors and heres my review
in non tow mode they are night and day difference from my oems .
in tow mode they stick out quite a ways as theres lots of maneuverability and thats good.
extended they do NOT vibrate
tuff to tell if the heat works since it was 80 + today but I adjusted them quite a bit to get different angles and views and had no issues .
05-03-2012, 08:45 PM
What brand were those and what was the cost ?
05-03-2012, 11:15 PM
Drinkin beer on the beach
nice write up. You're gonna have me spending more money...
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
05-04-2012, 08:37 AM
Thanks Rod!
I just couldn't see spending 800.00 to a 1,000 dollars on oems.
we have used these in the past for work so I knew they were the right piece
For the price.
I wanted one with a turn indicater but couldn't see spending
The extra 150.00 and still having the body module reprogramed since mine didn't come
with turn indicaters.
I am going to by led markers and install them such as the second link on previous post from ebay.
05-04-2012, 08:58 AM
Nice job turbo....your next install needs to be a full length video....
****That will be a big help towing !! *******
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
05-04-2012, 09:59 AM
But then I think about the dirty looks I'll get from other drivers stuck behind me. Now, I can't really see them.
05-04-2012, 10:06 AM
Good point !
I should take them back off!
Hmmmmm frf video how to section ....
I wonder if the powers that be are listening ?
05-04-2012, 05:11 PM
Alleged curmudgeon
Thanks Turbo! I had already bought mine (identical to yours) on eBay and received them yesterday. Your timing was perfect, as we're the instructions. My 2006 Silverado is good to go. Now if the new Windjammer would just hurry up!
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
05-04-2012, 05:26 PM
VERNK just alerted me that I posted that the right side had 2 connectors and left had one.
in fact its the other way around
d/s door 2 connecters
p/s door 1 connecter
thanks vernk !
05-04-2012, 07:05 PM
Jack of All Trades
Chevy Towing Mirrors
I've got a question for all that have changed to the Chevy (or GM) towing mirrors.
I put a set on very shortly after buying my truck. I had only made a few trips (not towing the trailer) prior to changing them.
My question is: Did you notice a change in fuel mileage after the change (when not towing)?
I can't say for certain, but I would swear I lost about 1 MPG at highway speeds after installing the mirrors (again, running bare without the trailer).
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
