Old 04-25-2016, 11:50 PM   #1
JD57's Avatar
3050DS rear ladder add on
Just picked up our used ( new to us!) 2016/15 3050DS-CD. It has no rear ladder and I would like to add one. I have been advised by the dealer that because of the full side slide for the bedroom, there is not enough supports to add a ladder. Dealer would have to remove back wall and add blocking, which would be very expensive. Has anyone else faced same problem and have possible solution.
2016/15 Sunseeker 3050DS-CD
JD57 is offline   Reply With Quote
Old 04-26-2016, 07:33 AM   #2
TURBS's Avatar
Normally if it didn't come with a ladder it cannot be added without great expense as you've found.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "2"
2015 nights camped "34"
Old 06-02-2016, 01:44 PM   #3
We are adding a ladder to our 2016 2306 because it didn't have one. The dealer took our VIN & contacted the factory rep & they said we could add a ladder. They said that after a certain date ( I can't remember) they added the blocking to all trailers.
Rcat is offline   Reply With Quote
Old 06-02-2016, 03:11 PM   #4
JD57's Avatar
Good to know. I'll look into this further when we travel south this winter. Hopefully the dealer in Arizona will be a bit more knowledgable.
Old 07-20-2016, 03:27 PM   #5
Finally got the ladder on the back of our 2016 FR Rockwood 2306. Turned out very expensive for a $120 option from the factory, lol. Click image for larger version
Name:	ImageUploadedByForest River Forums1469042710.661730.jpg
ID:	114759Click image for larger version
Name:	ImageUploadedByForest River Forums1469042754.212766.jpg
ID:	114760Also, I'm including a schematic from the factory that the dealer, Arbogast RV in Troy, Ohio got prior to the installation. There are support blocks inside the wall that were added by FR.
Old 07-22-2016, 12:56 AM   #6
JD57's Avatar
Ra at, if you don' t mind me asking how many hours did the dealer charge you for this work? Still trying to see how dealers come up with some of these times. Had my local dealer quote me 11 hours to do a wired back up cam and 2-3 hours to do a wireless setup. Ended up getting the wired ( ran it myself inside under a raceway as I added an extra HDMI and Cat5 cable from rear to front for future use) and dealer charged me 31/2 hours to do the camera work as well as add an XM radio head unit and auxiliary power switch to the Jensen.
Ford E450
Old 07-22-2016, 08:46 AM   #7
In my original quote, they told me 1 1/2 hours. When it came time to install it, they said it should've been 2 1/2. Told them no, so they did the original quote. Definitely could have done it myself, but didn't know where the braces were at the time. So, $125 for ladder, $135 for shipping, $250 for the installation. In the $250, there were some "incidentals", like sealers that raised the install cost a little.
Old 07-22-2016, 09:35 AM   #8
JD57's Avatar
Thanks for the info. Hope your ladder works out well.
