12-12-2011, 05:37 PM
All I did was mount the unit to a panel that I will install in a bottom compartment inside my trailer. To ensure the unit worked I made a temp outlet that ran from to allow our freezer to plug in. Unit worked great. In spring I will splice into the 12/2 wire coming inside the trailer from outside and be done with it. Unit has a delay of 2 min. before it allows power to run through trailer. I guess this is because it is checking for faults. Hope this helps.
2010 Ford F150 FX4
2010 Rockwood 2607 Ultra Lite - Purchased April 2010
2007 Harley Ultra Classic
2002 Ford Explorer
Nights Camped in 2010 - 35
Eastlake, OH
12-13-2011, 11:03 AM
Originally Posted by EastlakeRoo
I have been looking at both the 30 amp portable and the 30 amp hardwired Surge Protectors. I like the portable one because of ease of use and I like the hard wired one as its mounted in the trailer and I can sleep at night knowing someone hasn't walked off with my $200 surge protector.
I guess out of sight out of mind thinking..
Are there any other pros and cons to owning either? Im leaning towards the hard wired one but am waiting to here more feedback.
Let me know what you think.
We bought the 30 amp portable surge protector last year for our XLR based on recommendations made on this forum. I share the concern that someone one day will walk off with it at a campground. I bought the lockable hasp for the unit but it seems to be configured for round poles with the electrical connection. It just doesn't work at any park we have stayed at since they all had wooden square shaped poles.
Does anyone have any suggestions on how to secure the portable surge protector to ensure it doesn't disappear?
Thanks in advance for your suggestions!
Jim & Nicky
2012 Forest River XLR 29 MBV
2010 Dodge 2500 Cummings
Honda ST1100
BMW R1100R
12-13-2011, 01:18 PM
HI! First off do not connect it at the post end. Connect it at the trailer side. The protection is the same. If this is not enough for you you can use a short chain and a long shackle lock and chain the whole thing to your trailer bumper, Run the shackle over on one end of the surge protector. If they want it that bad they will have to repair the end to make it functional after they cut it off the lock or cut the whole lock and chain off.
I hid mine under the spare. That also kept it clean. Good luck.
regards,
Extremebike
2004 Ford F550 6l
2011 Sterling 32RL with Michelin XPS tires
12-13-2011, 01:50 PM
If your worried about some one skillfully acquiring your protection in the middle of the night - chances are it may as well disappear in the middle of the day while you and your family are out site seeing.
Hard wired inside your trailer is not only that piece of mind but a great reselling feature when it comes time. And at 200$ well its something you need only do once unless you sell.
I see people leaving BBQ units, 100 dollar chairs toys bikes etc out when they are gone for the week. We have become a society of blind trust with neighbors we will never see in many cases again.
Locked down but in sight was not the decision I went with. Built in was better.
2012 Salem 27RKSS
2011 Ford F150 Ecoboost 4x4
"Of the troops - For the troops "
12-13-2011, 03:06 PM
Moderator
Gosh - I need a visual on this because I'm having a hard time getting a picture of what you mean in my mind.
I've been plugging mine into the post and then locking the post lid with a padlock. I have the 30 amp unit from CW.
Great choice for "Living within my means" and camping for one... 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab 16 Trips / 43 Nights / 1204 Miles
12-14-2011, 07:17 AM
OK let's see if I can describe this better. Starting from the trailer end plug the surge protector to the trailer plug. I have a 50A to 30 A adapter so I connect the SP there. Then the extension cord to the post. My theory is that it takes real balls to come up to the trailer and start fiddling around to steal something. Most are grab and runs.
My old pop up had a 10 foot pull out 30A cord so doing this was easy. You may need an adapter at the trailer end.
Take a good long shackle lock like the ones we used to use on bicycles and capture one end of the surge protector. Then thread on the ends of a chain that is long enough to go around the bumper. If some one wants to steal the SP then they either need a bolt cutter or cut the end off the SP which then becomes useless to the thief. Good luck.
regards,
Extremebike
2004 Ford F550 6l
02-25-2012, 12:28 PM
I think the misunderstanding is because it sounds like extreme has a spot to plug his RV cord into the side of the trailer. Terier on the other hand has a set up like mine where you cord is hard wired to the trailer and you pull out what is needed and then push it back in when done.
Am I right here? If that is the case Terier cannot do what extreme suggested.
02-25-2012, 12:56 PM
Moderator
My powercord is the type that you hook up both ends - one end gets plug into the trailer and the other end to the electrical post (just like the fresh water hose). I have no easy way to secure the surge protector except to add a padlock to the electrical post. I don't believe the SP prongs will fit the electrical outlet on the trailer as this outlet has one L shape hole while the SP plug does not have the same L shape prong.
Due to budget reasons I opted for the portable plug & use unit. I don't have a husband that could install the hardwire type. My dealer could install it but price would depend on a couple of factors. Quite frankly there are a few things that could be easily stolen: Powercord, waterhose, P-tanks, battery, etc...
Take care,
Terie
02-25-2012, 02:06 PM
i opted for the portable version because the paperwork seems to suggest that a licensed electrician should be the only one to install a fixed one.
02-26-2012, 03:59 PM
Since we're on the subject of surge protector , If your TT is 30A (as ours is) if I install a 30A protector and visit a campsite that has a 50A outlet and I plug my 30A TT into the 50A outlet, what happens to the 30A surge protector? Should I install a 50A protector??? We travel alot and sometimes only 50A outlet are available.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 557 |
| 100 members and 457 guests |
| 4bnabird, amxpress, B47, bcunning, billy bob, Biscuit, bowshark, Buffalohunter, campers5delite, campnqueen, Canuck_Doug, Char_n_Kath, chiro, cousin01, dashonthedash, daveinpickerington, davidjb, daw592, DDC, dimurrrw, DonG, donn, duchie, Elidh, Filthy Beast, fonzie, freedom 750, gandr96, Gary0848, gerrym51, gimp425, Gman88, Goomph, gucci, herk7769, Hob, honda1, hoovercab, Huey1946, Hydrothunder, Iggy, Itsthetwoofus, jbk, Jeep4Two, JJFerg, Joseph5410, jpetrey, kathomas, KKapa, KRS, lochsa, Lumpty, mack63, Mad4sax, mamentt, milw156, mraynie, mtl roofer, mtnguy, NanaKaren, NeilM108, newby, NO3putt, NorminN.B., ns-sabre, Papa Roo, papap, PHS79, polkatronron, Poppy Bill, railstar, rbrandon, RGH, rickthelen, RickV, RJHuser, Rugged Brown, RV Guy, Sahgie, Saratoga Camper, sherdep, skipper194242, snipe, softwarejoe, sprayking, spurge1947, stevem4134, Tee, tfedd, thewren, Tincup13, tinker, Titleguy, Tom993, TopGobbler, troyt, wbdvt, will4u, wnytaxman, yworrydog |
| Most users ever online was 1,025, Today at 01:04 PM. |
