Originally Posted by MikeDett
Is 30amp and 50amp the same voltage? 120V or is 50amp 220V
30 amps is a single 120v line
50amp is (2) two 120 legs just out of phase - means the 120 legs are seperated
if it is was 220 it would be in phase
Originally Posted by Wiscampsin
Need Advive. We already have a Progressive Industries 30 portable. We're awaiting our new 50 Amp 5er ( 1 AC unit) to go on our 30 Amp seasonal site. Correct me if I'm wrong but if we're on a 30 Amp site this setup would be OK. Power Pedastal -> 30 Amp surge protector -> 30 to 50 amp dogbone adaptor -> 50 Amp power cord to camper.
you are limited to the 30 amp breaker
I would think you would be ok but keep in mind that when you draw more then 30 amps (too much stuff running inside the camper) you are going to be going outside to reset the breaker on the pole when it pops.
