Old 03-06-2012, 10:54 AM   #31
Originally Posted by sherdep View Post
30 amps is a single 120v line
50amp is (2) two 120 legs just out of phase - means the 120 legs are seperated
if it is was 220 it would be in phase
you are limited to the 30 amp breaker
I would think you would be ok but keep in mind that when you draw more then 30 amps (too much stuff running inside the camper) you are going to be going outside to reset the breaker on the pole when it pops.
Thanks.
