Old 08-18-2015, 08:32 PM   #1
Twistedpairs's Avatar
35 LED lights
With an annual boondock trip coming in early November and 23 incandescent lights in the cabin I decided to find some LEDs without taking out a second mortgage. At 35 each, I couldn't pass, I ordered two twenty packs and replaced all of my interior lights. Here's the link; 20pcs Cool White T10 Wedge 5050 5SMD LED 168 194 921 2825 License Interior Light | eBay
'15 26DBH pushing our '15 Ram 1500 w/ 10100# tow capacity
Twistedpairs is offline   Reply With Quote
Old 08-19-2015, 09:11 AM   #2
How well do they light.
Quiroule is offline   Reply With Quote
Old 08-19-2015, 09:20 AM   #3
rsdata's Avatar
please report back how long they last
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-19-2015, 09:26 AM   #4
peterbilt's Avatar
I got the same light and
they work well not sure how long none have quit yet
peterbilt is offline   Reply With Quote
Old 08-22-2015, 12:07 AM   #5
I chose the cool white light. They don't have the yellowish glow of incandescent and they don't get hot. Most LED manufacturers claim they last a lot longer but time will tell. Supposedly they only draw about 1/2 amp as opposed to the 10-12 amps of the original bulbs.
Old 08-29-2015, 07:34 AM   #6
f5moab's Avatar
Be interesting to see if these turn blue after being on for a while. I purchased some cheap LEDs for my popup, cool white like yours, and after being on for about 30 minutes, they started to turn blue.
Was told that can be common with some LEDs. Replaced with more expensive LEDs and they remain bright white regardless of time on.
f5moab is offline   Reply With Quote
Old 08-29-2015, 07:44 AM   #7
Flybob's Avatar
Do they cause interference on Radio or TV?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-29-2015, 07:47 AM   #8
KyDan's Avatar
My only issue with these is I wonder how bright they are. Do they appear to give as much light as the incandescents??
We had some of these and used them when boondocking but the ones I have aren't as bright as the hot/incandescent ones. I had to swap them back and forth in the bathroom so DW could see better when we were on shore power.
Our new rig has LED ceiling lights but they mess with the TV!!
We never had any trouble with these little wedge base replacements interfering with the TV tho...
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 08-29-2015, 07:51 AM   #9
peterbilt's Avatar
not had in problem with tv interference and my light seme to give off just as much light as before
2007 dodge ram 2500 2008 sabre 31 RKTS Knoxville Tenn
Old 08-29-2015, 08:11 AM   #10
f5moab's Avatar
Can't speak for a trailer, but can for a truck and a home.
Installed some cheap ones in my 2013 Pickup for dome lights, and had problems with bluetooth connections with my phone. Replaced with a better LED and the interference went away.
In a home, LEDs can cause interference in some items. Purchase some from Home Depot, and could not use in my garage door opener. Online read some problems with garage door openers and some LED bulbs. Purchased more expensive bulbs and problem went away. Problem was if the bulbs were On, and I tried to close the door from the truck, it would not close. However, if the bulbs were Off, door would close. With the more expensive bulbs, all works fine.
But inside the house, which is 90 percent LEDs (other 10% is fluorescent) I have had no interference with any component.
Some info....
http://www.emcrules.com/2011/07/radi...-lighting.html
led, light
