Old 05-27-2014, 10:15 PM   #1
4X4 Fence post mod. HELP me out! PLzzz
I have the 4x4 post 6ft long. I have the end caps.. NOW,, I'm stuck.
I don't know whether to put it on top of the back bumper(which has the ubolt from the spare in the way) Or to put it under the camper. I have the Shamrock 21dk..
Annnnd after I figure that out.. How am I supposed to attach it? I can't find any 10 inch ubolts out there that would attach both bumper and post.
Should I use metal straps..
Any help would be appreciated.
Sheripoms is offline   Reply With Quote
Old 05-27-2014, 10:23 PM   #2
Oklahoma Proud
MillerTime's Avatar
I welded my own brackets cause I had to space my box down because of propane pipe on the bottom of my frame. Others have use some strap and all thread.
My next ones I will probably just bend some 1/8" x 1"or 1.5" to fit around the box and then bolt to my spacer bar.
( oh and the screws holding my box from moving, I ran screws in, then backed out and cut tips off so they didn't stick into the box)
Millertime- Sabre Handler
ID:	53502   Click image for larger version
ID:	53503   Click image for larger version
Old 05-27-2014, 10:35 PM   #3
jtstromsburg's Avatar
Pics
Sent by me
ID:	53509   Click image for larger version
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 05-27-2014, 11:17 PM   #4
I went the simple route. I drilled two 1 inch holes about 18 inches in from the ends and then screwed up through the far side into the frame of the trailer with self-taping screws with large fender washers. It hasn't come off yet!
2008 Tundra Crewmax
2013 Tracer 3150 BHD
lvnthenw is offline   Reply With Quote
Old 05-28-2014, 04:59 AM   #5
Toy-aholic
I went to the electrical dept. of Lowes and got mega tie raps and they worked great
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 05-28-2014, 05:26 AM   #6
Herk7769's Avatar
Be careful with this. Most Zip Ties are not UV stabilized and they become fragile with age in the sun. Not sure about Megaties...
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-28-2014, 07:00 AM   #7
ChibullsAN's Avatar
I used 5x5 posts just in front of the axles. They are attached to the frame using beam clamps. Then all thread or long bolts through a piece of c channel aluminum. I have 3 under there for my ladder, sewer stuff and directv dish stand. All on my 21dk.
2018 Rockwood Signature Ultralight 8329SS
ChibullsAN is offline   Reply With Quote
Old 05-28-2014, 07:01 AM   #8
ChibullsAN's Avatar
You can zoom in and see here.
Old 05-28-2014, 07:11 AM   #9
What kind of ladder fits into a 5x5 post tube?
Old 05-28-2014, 07:16 AM   #10
This kind.
Folding Ladders & Step Ladders, Best Folding Ladder | Folding Ladder System | ladder-guy.com
Old 05-28-2014, 11:26 AM   #11
cbvp's Avatar
ladder
Here ya go.
C.B.
cbvp is offline   Reply With Quote
Old 05-28-2014, 02:30 PM   #12
ChibullsAN's Avatar
Yup. That's the one.
Old 05-28-2014, 02:35 PM   #13
Ford Idaho's Avatar
Those ladders are so freaking cool......
Old 05-28-2014, 03:12 PM   #14
Love those ladders
___________________________________
Salmon Hunter
2011 Crusader 320 RLT/ Honda 3000ei
2006 Chevy 2500HD 4x4 Crew Cab/Duramax Diesel/Allison Transmission
Salmon Hunter is offline   Reply With Quote
Old 05-28-2014, 03:19 PM   #15
sammonilla's Avatar
Wow, That is a cool ladder.
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2016 SILVERADO 2500HD 6.6 Duramax
2012 280BH Casscade
sammonilla is offline   Reply With Quote
Old 05-28-2014, 04:52 PM   #16
golfmedik's Avatar
I drilled the frame lip and put bolts through mine with aluminum tubing under it. You will also notice a piece of tubing on top. The reason for that was I had to clear the propane line. That top tube keeps it from rubbing.
Monty
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 05-28-2014, 08:17 PM   #17
camaraderie's Avatar
To the OP...this meets your search criteria for a U bolt. Pricey though.
Square Bend U-Bolts - 3/4" x 4 1/16" x 12 7/8" - 361-200 | $29.95
camaraderie is offline   Reply With Quote
Old 05-29-2014, 12:25 AM   #18
Wow that is pricey!. I may have to get my Step father to see if he can rig something up.
Old 05-29-2014, 12:44 AM   #19
Webfoot
I was able to find a couple steel plates connected right to the frame right in front of the front stabilizer jacks that I was able to get a 7" hose clamp around.
ID:	53618   Click image for larger version
ID:	53619   Click image for larger version
ID:	53621   Click image for larger version
2012 Chevy Suburban 1500
2012 Surveyor SP-260
quackor is offline   Reply With Quote
Old 05-29-2014, 05:20 AM   #20
BiigDaddy's Avatar
I used hose clamps and attached mine to the spare tire bracket...
Sent from my EVO using Forest River Forums mobile app
ID:	53626   Click image for larger version
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
modifications
