Old 03-30-2016, 05:15 PM   #21
Originally Posted by wmtire View Post
Gordon, you are not tying together the L1 and L2 hot lines coming FROM the service when using the adapter. You are only using the L1, and then jumping/sharing it over to the L2 going INTO the RV.
There is no L2 line coming out of a 30 amp service. See the schematic on post #15.
Indeed, I stand corrected. The jumper is on the split phase wiring system, but you aren't shorting anything that has power on it, because you don't have split phase coming.
This leads to another interesting issue. My Magnum Inverter panel asks me to tell how many amps I have on my shore power: 15, 20 or 30. I assume it knows it has 50 if it sees 220 volts between the hot sides.
But, the Magnum also says that it will shut off circuits that aren't being used to keep within the power limits. Is it only doing that when inverting from battery power, or does this load management also work when on shore power? If it works when on shore power, it might not be necessary to join the two sides together, because the Magnum could handle the necessary transfers.
Gordon Sick, Calgary (51° North)
2015 Berkshire 34QS
The Manual I wrote for our 34QS:
https://www.forestriverforums.com/fo...ml#post2579202
Toad: 2019 Ford Ranger XLT 4x4; Formerly: 2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 03-30-2016, 05:27 PM   #22
Great post with diagram!
Harkerr is offline   Reply With Quote
